Okay I have this sound coming from the front of motor it hard to disscribe but its kind of wrupp wrupp sound and also a kind of metal rubbing sound . At first i thought water pump but today after laying under truck and watching compressor kick in the sound gets louder and when it kicks off the metal rubbing sound . Oh and besides for the refregerant leak AC works fine for now. Any of yall have a compressor make sounds like this, something tells me its on its way out.
Wonder nif it leaked all its refrigerant oil out??? and started burning it up
Was you refilling the A/C system during the winter to??? I remember you had a Leak last summer. And since the A/C compressor DOES engauge when defrost is on at minimum maybe it engauges at 1 other setting to cant remember it could have ran dry IDK
Yeah first thing (like stated above) is to remove your serp belt. I chased a noise on my old 7.3l and it turned out to be a idler pulley. I changer out ac comp, water pump, powersteering pump, alt, etc So be sure to check the air gap on the a/c clutch and if its good id say if you had a leak it probably from the ac compressor and thats the root of all your problems. Just my $0.02
Thanks guys i will try the suggestions , but got a feeling my compressor is going . Benny didn't do anything over easter put a thermo on truck and found out i have rear axle bearings on jeep going out. And did some things around house. How was your weekend?
