Long Crank Time
Old Feb 17, 2015 | 01:45 PM
Traildust's Avatar
Traildust
Long Crank Time
My truck has started to take longer to get it started and it doesn't matter if it's warm or cold. Over the weekend I replaced both the HPOP lines and all four fittings, not because of the long crank time but because I had planned on doing it anyway. They are almost 13 years old so I figured it's about time. Got it all back together and then my crank time more than doubled . In the process of trying to figure out why I found the small red wire on the GPR was really loose, tightened it down and the long crank time is fixed. I was sort of hoping for a bad GPR since I already have a White Rogers(Stancor) standing by. The original OEM GPR is still on it.
Bill
Old Feb 17, 2015 | 02:42 PM
white Buffalo's Avatar
white Buffalo
If you alresdy have Stanor GPR in hand I would consider swapping it out. Pretty simple & quick to do as you know. Better off doing it at home or in a warm garage than on the road during the winter......
Old Feb 18, 2015 | 03:16 PM
Traildust's Avatar
Traildust
You got that right!
Bill
Old Feb 20, 2015 | 08:19 AM
Tugly's Avatar
Tugly
When you replaced your HPOP lines, you introduced air - it will make a long start condition until you drive the air out (about 50 miles). Long starts are most typically ICP, GP, or injector/O-ring issues. If you have a scan gauge/tool, look at your ICP and IPR while cranking - 2200 PSI ICP with 30% IPR is about normal.
Old Feb 20, 2015 | 09:08 AM
ihfarmboy93's Avatar
ihfarmboy93
also a way to get the air out is to take the oil pressure sensor off the top of the head.. theres almost always a little air that gets trapped up there...u might have to just add a touch of oil into the hole then out the sensor back in.. this may or may not help your long starting issue
Old Feb 20, 2015 | 04:02 PM
Traildust's Avatar
Traildust
Thanks all, I did drive it about 40 miles before I found the loose wire on the GPR. Now it starts so quick I can barely get a cranking reading of IPR/IPC. I just remembered that I have the No Start Programed into my Hydra so I went out and gave it agood crank time and saw a solid 37.6 IPR and around 2250-2300 ICP. It's funny how that loose red wire was causing my crannk times to increase. I did add oil back in the HPOP reservoir before I even tried to start it.
Thanks Again,
Bill
Old Feb 21, 2015 | 12:05 AM
ihfarmboy93
just changed glow plugs in our 99 a few weeks ago.. even if you ran them twice in a 45 degree shop it wud barely start.. only 2 tested good and one slightly good the rest did nuthing at all.. only took me 3 hrs to change em.. thats why i like the 7.3.. i can work on it.. took me n my friend 6 hrs just to get to the valve covers on his 01 duramax...
Kemicalburns
Jul 28, 2016 11:50 AM
rwallen85
Nov 26, 2015 02:47 PM
Archy
Oct 22, 2015 03:15 PM
good2eat
Dec 14, 2013 09:54 PM
bama29fan
29
May 25, 2010 03:08 PM
