Sponsored by: Real Truck
2015 high idle?
Old Feb 15, 2015 | 06:51 PM
bracyder's Avatar
bracyder
2015 high idle?
I'm going to cut right to the chase, when did ford stop having the diesel high idle when it is cold? I have a 2015 350 I bought last August and assumed it would high idle like previous power strokes. I even put a ts6 chip in my 97 just for high idle option to keep the motor warm when idling around our farm. I realize ford probably doesn't want trucks idling long because it kills mpg and isn't good for the emission system but to be honest I could really care less about mpg as long as it's decent and a high idle would help keep emissions pushed through. Is there an option or anyway you can get the 6.7 liter to high idle?
Old Feb 15, 2015 | 09:53 PM
McFarlandkm's Avatar
McFarlandkm
They do have high idle from the factory for cold weather operation. Mine goes up to about 900-1000 rpm vs <600rpm. The outside temp has to be cold enough, somewhere in the 20s. You can add s manually activated high idle if you choose. Go over to the tech folder under the 6.7 diesel section and look for the seic mod.
https://www.ford-trucks.com/forums/1...ml#post9494561
Sent from my SM-G900V using IB AutoGroup
thedotz
Feb 2, 2016 08:24 AM
Curt's05
Nov 24, 2013 08:03 PM
EXbowtieguy
Oct 31, 2011 09:50 AM
Acftmaintainer
Sep 9, 2010 06:39 PM
Golflug
25
Feb 11, 2008 09:38 PM
