Sponsored by: Real Truck
TorqShift Temperature Range
Old Aug 27, 2013 | 05:17 PM
stimm32's Avatar
stimm32
Howdy all,
I finally got around to installing a transmission temp sensor in our '06 F250, and I have noticed today that it seems to be at 180 degrees regularly driving around town unloaded. It has been around 80-85 degrees outside today. We just got this truck about a month ago, so I'm still getting used to its little quirks. On our old 7.3 with a 4R100, it wasn't at all unusual to see 180 on a day like today around town. Is this normal on a TorqShift?
Old Aug 27, 2013 | 08:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's about right for around town. Where do you have the sensor located?
Old Aug 27, 2013 | 08:53 PM
ATP Pilot's Avatar
ATP Pilot
Hey Mark,
I notice on my scangauge reading from the OBDII port, that my 6R140 runs about 200-205 towing or not. Truck Trans gauge in about the 11'o clock postion at this temp.
This is fully warmed up, highway speeds and mid 90's outside temp. Seems a little high? Is this normal for the 6R140 and the 6.2?
Thanks in advance
Old Aug 27, 2013 | 09:54 PM
Mark Kovalsky
I've never seen a 6R140. I do not know what temperature they are designed to run at. I have seen several posts that report similar temperatures to yours.
Old Aug 27, 2013 | 09:58 PM
stimm32's Avatar
stimm32
It's right in the test port. However, after I posted this, I noticed the driveway smelled like transmission fluid. Turns out I didn't have an O-Ring on the trans temp gauge sender, so it was leaking all kinds of fluid, as you can imagine.
So, long story short, I got an O-Ring and put some more ATF in it, and now it runs about 160-170, max.
Thanks for helping me through one of my less prudent times!
Old Aug 29, 2013 | 07:30 PM
stimm32's Avatar
stimm32
I have read that there is an internal thermostat that circulates fluid at 165. If the trans is at 180, shouldn't it start circulating the fluid through the coolers and cool it right on down?
Old Aug 29, 2013 | 08:02 PM
Mark Kovalsky
Yes it should. Sometimes it is making enough heat that the coolers can't get it back down to 165°F.
Old Aug 30, 2013 | 10:17 AM
Trophy_23's Avatar
Trophy_23
With my insight I see a TFT always around 150ish unloaded. I've never seen it near 180.
Old Aug 30, 2013 | 08:54 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
X2 150-160 is the usual range for me. I have to work the **** out of it to see anything over 170.
Josh
Old Feb 12, 2015 | 04:01 PM
Gage2502's Avatar
Gage2502
So since the external filter only filters 90% when the transmission is at or over 165 degrees are we in trouble due to the filter only working at 10% when below 165 degrees?
...Gage
Old Feb 12, 2015 | 08:54 PM
Mark Kovalsky
You have that wrong. The filter filters 10% of the flow through the cooler lines. When the thermostat is closed the flow is reduced by 90%. So it filters 10% of the cooler flow hot, which is not all the flow in the trans. Then that is reduced by 90% cold, so less than 1% of the fluid is filtered cold.
Compare this to a 4R100, where ZERO% of the fluid ever sees a filter like this one.
Old Feb 13, 2015 | 02:17 PM
Gage2502's Avatar
Gage2502
Thanks again Mark.....I think Im over thinking this whole transmission cooling and filter system.
....Gage
Old Feb 15, 2015 | 06:34 PM
chrislambing's Avatar
chrislambing
Originally Posted by stimm32
Howdy all,
My 11 cc lb 6.2 runs ~185 loaded or not. In heavy stop and go traffic I've seen 200.
Old Feb 15, 2015 | 10:25 PM
Tennesseepowerstroke's Avatar
Thanks Mark for ALL OF YOUR CONTRIBUTIONS to this forum.
Xqsless
Jan 3, 2019 06:57 AM
gpf2ez
Mar 24, 2017 12:19 PM
coppervette
6.4L Power Stroke Diesel
Dec 31, 2015 05:08 PM
BASSHUNTER
Jul 27, 2006 05:22 PM
macman85602
May 8, 2004 09:56 PM
