8 Volt Battery
Old Feb 24, 2015 | 01:15 PM
  #46
Jolly Roger Joe's Avatar
Jolly Roger Joe
Originally Posted by ALBUQ F-1
All the tests are covered in the Workshop Manual.
So if I'm reading at that correctly, the test simply bypasses the regulator.
What I don't understand is how I have in the past read 7.4 volts on the battery terminals while running at high idle. That's why I said to test it that way. It would seem to me that would show if the generator and the regulator are working.
Old Feb 24, 2015 | 01:59 PM
  #47
ALBUQ F-1's Avatar
ALBUQ F-1
You're correct, Joe. It "full-fields" the generator, telling it to put out full output. It eliminates (or confirms) the generator as the problem. If it works, then the regulator needs attention, perhaps just an adjustment, maybe replacement.
If everything is working correctly, right after starting the generator will likely be putting out 7.4v to recharge the battery. Your test tells whether the system as a whole is working, but doesn't isolate the problem if you get a low reading.
Old Feb 24, 2015 | 02:31 PM
  #48
Tedster9's Avatar
Tedster9
Testing the voltage output at say 1500 RPM, is a good quick test, tho voltage is only part of it. A generator actually runs full tilt all the time, the regulator itself throttles the voltage and current back as load demands. Full fielding basically indicates that the generator can both handle the current requirement of lights and heater blower and charge the battery as well. Corrosion and rust are the big enemies of a healthy charging system.
Old Feb 24, 2015 | 03:32 PM
  #49
Jolly Roger Joe
OK, I got it now. I guess I was just lucky everything was working when I checked the voltage. Actually, I did that after I rebuilt the generator. I never read the test procedure out of the Shop Manual. I don't think my ancient Fluke meter will measure up to 50 amps anyway. I'll have to look.
EDIT: I just checked my meter. It is limited to 2 amps.
Old Feb 24, 2015 | 03:45 PM
  #50
Tedster9's Avatar
Tedster9
I ran into the same "problem" and solved it with this: (more tools are always a Good Thing)
Old Feb 24, 2015 | 05:05 PM
  #51
Clint1950f5's Avatar
Clint1950f5
One other quick question. Are these systems supposed to keep the motor running if the battery is disconnected after the motor is started? Sorry if this is a stupid question.
Old Feb 24, 2015 | 05:18 PM
  #52
ALBUQ F-1's Avatar
ALBUQ F-1
A generator will keep the engine running; some alternators will, some won't. Some alternators burn up if you disconnect the battery.
Old Feb 24, 2015 | 11:57 PM
  #53
Tedster9's Avatar
Tedster9
Technically the battery's only purpose is to start the engine, the alternator or generator provides all of the voltage and current required for lights, ignition and accessories. It also acts as a filter of sorts to smooth out voltage spikes or sags. This is one reason why disconnecting the battery while engine is running can cause system voltage to spike dangerously high. A generator is a little different in that it utilizes a low RPM cutout at the regulator, since it cannot produce enough voltage at idle. The truck will draw on the battery then. A battery with good reserve capacity helps here, not just CCA.
79F-1504x4
53
Mar 3, 2011 01:53 PM
ac700wildcat
Garage & Workshop
Jul 23, 2010 07:11 PM
qman
16
Jul 16, 2009 09:19 PM
blanes
Jan 9, 2008 09:52 PM
gravydude
Jul 11, 2007 11:02 AM
