8 Volt Battery
Old Feb 14, 2015 | 10:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Sounds like the generator isn't producing anything, or the regulator isn't telling it to. Pt the battery on a charger overnight and measure voltage at the battery with the engine running at 2000 RPM or so.
Old Feb 14, 2015 | 11:18 PM
idahoal's Avatar
idahoal
Sounds like a bum ground connection.check and clean ground and other battery coonections.or the cables are corroded under the insulation.
Old Feb 14, 2015 | 11:28 PM
havi's Avatar
havi
I'll have the Roast Duck
With my block heater plugged in for a few hours, my Golden Jubilee will fire with a squirt of ether at -20F. So I have no qualms with a 6v battery at cold temps. I plan to "upgrade" with a red optima in the future. BTW, I agree with Ross.
Old Feb 15, 2015 | 12:05 AM
Tedster9's Avatar
Tedster9
Most people today are familiar with an alternator charging system, they provide charging current at idle. Not so with a generator. The cutout - and that's what it is, kicks at about 1300 (generator RPM) or so. So the battery has to pick up the slack at low engine RPM. It doesn't take much to tip the scales, a couple long cold cranks, short trips with stop and go driving, a little rust and corrosion here and there, flip the headlights on, she's done.
CCA is important for easy starts but also, sufficient reserve capacity. Use the biggest and heaviest battery that will fit and charge it up thoroughly before installation. Generators do not like resistance in the connections and grounds. Neither do alternators as far as that goes, but generators are already behind the eight ball so everything has to be squared away.
Did the GEN light illuminate, or is this an ammeter?
Old Feb 15, 2015 | 12:41 AM
Clint1950f5's Avatar
Clint1950f5
It is ammeter. The needle was pointing a little toward the discharge side. At one point the temp gauge read hot and then when back to the normal position.
Old Feb 15, 2015 | 12:43 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Originally Posted by bigwin56f100
I don't think so...... Each cell of a battery is 2.1 volts and a 6 v battery has 3 cells so a fully charged 6 volt battery is 6.3 volts
A charging system should show around 7.4 volts running at the battery
Yes, that's actually what I meant to say...
Old Feb 15, 2015 | 01:11 AM
fladoodle's Avatar
fladoodle
I'd look at your generator next. Very common for them to get old/wear out on these trucks. A rebrush/rebuild could be done yourself or reasonably at a reputable shop in your area. Edit: Just saw all the replies, don't know why they weren't showing..
Old Feb 15, 2015 | 01:23 AM
Tedster9's Avatar
Tedster9
Yep. It's pretty common for people take great pains on the motor rebuild, but then reinstall a worn out generator and then bitch they aren't reliable. They will not handle anything above 6 grand but other than that they work fine. Heavy *******s though!
Old Feb 15, 2015 | 03:43 AM
FortyNiner's Avatar
FortyNiner
X4 on the generator. It all sounds very familiar.
Old Feb 15, 2015 | 06:28 AM
raytasch's Avatar
raytasch
Believe Nothing
Originally Posted by abe
Ray,
Can you explain that please. So you are saying keep it in gear with the clutch pedal depressed as opposed to putting it in neutral?
The key is just have the clutch depressed. With the clutch depressed the transmission is disconnected at the clutch. With the clutch released and transmission in neutral, the starter must turn the transmission main drive and cluster gear, both of which are restricted somewhat by heavy gear oil, added drag on the starter.
Perhaps Clint's truck just needs driven at speed for an extended period
Old Feb 17, 2015 | 03:36 PM
ktgovols's Avatar
ktgovols
I just saw this
Back in day, I drove my 52 F-1 every day. It was my only transportation to HS and college and to work. It had the 6 volt positive ground system in it the whole time I was driving it daily (1983-1990).
I had an 8 volt battery in it the whole time. I adjusted the voltage regulator up to 9.2 volts the only reason was so it would crank easier on both extremely cold and hot days.
I used 6 volt bulbs. I don't recall them blowing that often. I probabably changed headlights once in that time. I don't recollect changing the dash lights or the parking lights. I did go through a lot of taillights. Brake lights to be more specific.
I had no resistors in the gauges, nor the coil. They were fine. The heater ran fine too as did the electric wiper motor. My pickup originally had vacuum wipers but I found an F-3 in a junkyard with electric wipers and I swapped them out.
Keith
Old Feb 17, 2015 | 07:53 PM
fladoodle's Avatar
fladoodle
This reminds me, I had mentioned thinking about a 12V system to my great-uncle. He was very adamant that was not necessary, telling me that if he knew it would be really cold the next morning for his morning work with the cows, he'd hook up the trickle charger, and, even when it was 30 below, he had no trouble starting it, especially if he used the coke. I don't doubt this one bit. These trucks may crank slow with 6 volts, but when they catch, they catch.
Old Feb 17, 2015 | 09:17 PM
  #28
ALBUQ F-1's Avatar
ALBUQ F-1
What I've found makes a huge difference for starting is a modern gear-reduction, permanent magnet starter. The field coils on original starters suck a bunch of current, and they crank slowly because of the direct gearing to the flywheel. Combined with the alternator that instantly recharges the battery, it's a really robust system. I realized last summer that my battery is 10 years old... I'm tempted to replace it "just because", but it starts great even with temps in the mid-20's.
Old Feb 17, 2015 | 09:24 PM
  #29
fladoodle's Avatar
fladoodle
Could you post a link to an example? I've never seen a modern starter setup in something as old like our trucks, granted I've never really thought to look.
Old Feb 17, 2015 | 09:54 PM
  #30
abe's Avatar
abe
Interesting, Ross. I had a 6 volt battery last 10 years. My current 6 volt battery is 6 years old and going strong.
