Automatic Transmission Question
Old Feb 14, 2015 | 05:43 PM
dieselsubmariner's Avatar
dieselsubmariner
I just bought my wife a 1996 F350 CCLB SRW.
when you take off with the truck, the transmission starts in 2nd gear instead of first. when I stop, it only shifts down to second. This is only with the shift lever in D. I can however shift it manual down to 1st and then back up to D. Transmission does not slip. no codes are flashing.
Any Thoughts?
Old Feb 15, 2015 | 12:22 AM
sean9049's Avatar
sean9049
i dont know much about transmissions, but hows your fluid? how many miles on the trans? could be a shift solenoid?...when you put it in first manually how does the gear feel? i figure other guys will chime in i dont want to throw things out there and look stupid lol
Old Feb 15, 2015 | 04:54 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Have you checked for codes?
Old Feb 15, 2015 | 07:19 AM
dieselsubmariner
Transmission fluid looks clean and does not smell burned. level is good. no leaks on the Transmission. Miles on the Truck are 185K.
I do not see the OD Light flashing. How do i pull codes if there are any ?
If i shift manually, everything seems normal. no slipping or hard shifting.
thanks
Old Feb 15, 2015 | 07:53 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You pull codes with an OBDII scan tool that has Ford specific software. 1996 was a very difficult year to get codes. The people that wrote the code for that in the 1996 PCM didn't really understand what they needed, so it doesn't always work right.
You could have a bad shift solenoid, or a stuck shift valve. The codes should help narrow that down.
Old Feb 15, 2015 | 08:06 AM
dieselsubmariner
I should have my auto enginuity by either tomorrow or Tuesday . Hope this will read any codes.
Old Feb 15, 2015 | 10:05 AM
sean9049's Avatar
sean9049
AE is one of the best imo
hondamxr
Mar 7, 2019 05:13 PM
joncow
Oct 1, 2018 03:32 PM
whatusername
May 4, 2016 09:12 PM
anton19
Apr 15, 2004 11:07 PM
trsest1
1983 - 2012 Ranger & B-Series
Apr 2, 2004 10:07 PM
