My build so far...
Old Feb 10, 2015 | 04:35 AM
48/51F1's Avatar
48/51F1
My build so far...
1948 f1.
Originally red, flathead 6 with a 4 speed and Dana 41 rearend.
Old Feb 10, 2015 | 04:45 AM
48/51F1's Avatar
48/51F1
When I first acquired this truck in 2008 I never thought I'd have done so much work to it, I wanted to restore it all original, so first of I redid all the stock brakes new and slapped some rubber on the wheels to get it rolling around.
Old Feb 10, 2015 | 05:22 AM
JPMallory's Avatar
JPMallory
Nice looking ride!
Old Feb 10, 2015 | 06:02 AM
48/51F1's Avatar
48/51F1
The truck didn't come with an engine or front end. So I tried to get an original engine, and found one on ebay. I even won the auction, so I paid the winning bid and began to arrange shipping from Michigan to California. And that's when I decided to go a different way. And it made things so much easier. I was able to source a rebuildable sbf and transmission within driving distance on
ebay for 300.
Old Feb 10, 2015 | 06:57 AM
48/51F1's Avatar
48/51F1
Thanks. It's back in the garage now, I got the bed off and I'm doing some much needed metal work
Old Feb 10, 2015 | 07:06 AM
48/51F1's Avatar
48/51F1
While rebuilding the motor I found a 1951 f2 complete front end for 150. F2 wheel arches are way bigger than the rear f1 fenders arches so it looked funny but better than nothing.
Old Feb 10, 2015 | 10:37 AM
Fishalbuq's Avatar
Fishalbuq
Don't think the fenders are bad at all, I ended up using 3/4 ton fenders on mine and I think they work. Nice truck.
Old Feb 10, 2015 | 10:58 AM
schoo's Avatar
schoo
looking good Justin how are you doing on the clutch linkage?
Old Feb 10, 2015 | 05:35 PM
48/51F1's Avatar
48/51F1
Schoo..Linkage
Nothing yet, been doing cab corners.
and when that's done I'll be doing that back panel on the cab, then the floor and front cab corners. That linkage I made did not work too well, it was pulling from the wrong angle and binding.
Old Feb 10, 2015 | 05:40 PM
schoo's Avatar
schoo
that rust on the back doesn't look to deep can you sand out
Old Feb 10, 2015 | 05:42 PM
trumph's Avatar
trumph
Nice looking truck
Old Feb 11, 2015 | 06:34 AM
48/51F1's Avatar
48/51F1
Schoo
The rear of the cab is pitted pretty badly with pin holes. The bed panel is kicked in and was rubbing for who knows how long.But I've got a 4x10 sheet of 18ga. So I'm gonna use it up.
Old Feb 17, 2015 | 05:12 AM
48/51F1's Avatar
48/51F1
Been making my way around the cab, mostly just cutting stuff up so far, made some replacement pieces and started getting em in place but it's been slow going.
Old Feb 17, 2015 | 06:34 AM
49willard's Avatar
49willard
Your fabrication work looks great. Have you purchased new front cab corners? They are a quality piece for very reasonable $ and you will need to put them in before welding in that floor panel.
Old Feb 17, 2015 | 08:45 AM
r_reed's Avatar
r_reed
nice looking fab work. most of us have had to deal with floors and cab corners. your's are coming out nice.
