My build so far...
Old Feb 18, 2015 | 01:27 AM
48/51F1's Avatar
48/51F1
Yes I bought cab corners front and back both sides, but on the front passenger side I just made a patch panel wasn't much affected area.... on the outside.
Old Feb 18, 2015 | 01:29 AM
48/51F1's Avatar
48/51F1
Old Feb 18, 2015 | 02:47 AM
48/51F1's Avatar
48/51F1
Old Feb 18, 2015 | 07:48 AM
DougofMontana's Avatar
DougofMontana
Great looking fabrication work! Subscribing
Old Feb 18, 2015 | 07:55 AM
ben73058's Avatar
ben73058
Hey Justin,
Your cab is looking good! The cabs take the most work - hang in there - it goes a lot faster once you get past the cab. We had to replace our door pillars - tricky. We didn't have much luck with sheet metal parts fitting from the major suppliers so we got our replacement parts from another member here who makes them - Reamer. They actually fit.
Good luck up there in Norcal - You are getting there.
Ben in Austin
1950 F1
Old Apr 16, 2015 | 09:43 PM
48/51F1's Avatar
48/51F1
update... so far.
Fabbed some stuff today. Made a mount for clutch cable I'm hoping works better than previous attempts.
Old Apr 16, 2015 | 09:46 PM
48/51F1's Avatar
48/51F1
Old Apr 16, 2015 | 09:49 PM
48/51F1's Avatar
48/51F1
Stills needs to be duplicated so I can see if it works.
Old Apr 16, 2015 | 09:57 PM
48/51F1's Avatar
48/51F1
Old Apr 16, 2015 | 10:22 PM
schoo's Avatar
schoo
I hope works also Justin keep the pic coming
Old Apr 16, 2015 | 11:36 PM
48/51F1's Avatar
48/51F1
Old Apr 16, 2015 | 11:37 PM
48/51F1's Avatar
48/51F1
Finished another one. See if it works
Old Apr 18, 2015 | 08:48 PM
  #28
48/51F1's Avatar
48/51F1
Old Apr 18, 2015 | 09:13 PM
  #29
48/51F1's Avatar
48/51F1
Withh all the adjustment taken up seems to work well, but my cable length is a hair too long so I'll cut and reinstall new threaded end.
Old Apr 20, 2015 | 04:38 PM
  #30
48/51F1's Avatar
48/51F1
Got Got a p.s. pump mounted up with a belt that fits well, now to get the plumbing sorted.
