How to replace window seals?
Old Jul 22, 2003 | 11:20 AM
loudfords's Avatar
loudfords
Question How to replace window seals?
I haven't been able to find this using the search function. I have all new window seals for the roll-up windows in my 79. Are there any special steps I need to follow to replace the window seals? Do I need to pop off the door panel? I'm assuming I don't need to remove the window itself?
Old Jul 22, 2003 | 04:56 PM
Native Gearhead's Avatar
Native Gearhead
I hope this image shows up.
Old Jul 23, 2003 | 12:23 PM
dfisher1's Avatar
dfisher1
Loud,
I've done window (fir/fur?) strips quite a few times and I've never had to dissassemble the door. Take your time. The hardest part maybe getting the old decaying pieces out. Use a small screwdriver to pullout the pieces at the bottom of the window. Be careful, its easy to dent or scratch the edge of the door. Take your time, you only have to do it right once. I usually take the opportunity to clean/paint the inside of the door where your arm has worn away the paint. I'm not sure but, I think that a Ford truck door, with the window down, maybe the best place to rest your arm in the world!
Go figure?
KingFisher
Old Jul 23, 2003 | 12:32 PM
loudfords's Avatar
loudfords
Thanks dfisher. You didn't need to remove the window at all? Did you remove the door panel?
Old Jul 23, 2003 | 12:43 PM
dfisher1's Avatar
dfisher1
Loud,
If you can't get the old piece out you may have to pull the panel to dig out the leftover chunks.
Other than that, do it assembled.
KingFisher
Old Jul 23, 2003 | 12:50 PM
loudfords's Avatar
loudfords
Superb. Thanks
Old Jul 24, 2003 | 12:38 AM
Torque1st's Avatar
Torque1st
Posting Legend
By the time you worm each part out and drop some inside the door, it is probably just easier to take the door panel off first anyway.
Old Jul 28, 2003 | 11:06 AM
loudfords's Avatar
loudfords
I replaced the passenger side window seals Friday night and I needed the door panel off to place the new seals in the grooves properly. Now my window rolls up crooked, it did before too but now the problem is exagerated, is it possible that the window is undersize or something?
Old Jul 28, 2003 | 12:34 PM
dfisher1's Avatar
dfisher1
Loud,
Unlikely, the metal track that the fir strip slides into is adjustable. Pull the panel and see if the track is loose or broken. Adjust it and you'll be good to go.
KingFisher
abyars111
16
Jul 21, 2015 06:55 PM
notthemaniusedtobe
26
Apr 2, 2015 02:07 PM
awdonly
Apr 28, 2014 04:16 AM
vermillion95xl
Jan 15, 2014 07:09 AM
Ultramagdan
1997 - 2003 F150
Aug 26, 2003 07:12 PM
