Transmission
Old Jan 29, 2015 | 06:31 AM
Tcook1687's Avatar
Tcook1687
Thanks you guys have been a great help. Now if I can just fiqure out what modifications are worth doing to a 360 without going stroker
Old Jan 29, 2015 | 06:37 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Have you been here yet? Might get some direct answers?
FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) - Ford Truck Enthusiasts Forums
Old Jan 29, 2015 | 11:21 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
360/390's share the same bore (4.05"), the stroke is different.
360 = 3.50" / 390 = 3.78"
So, all one needs to convert a 360 to a 390, is the 390's crank, rods and pistons.
Old Jan 29, 2015 | 06:38 PM
Tcook1687's Avatar
Tcook1687
So a up date for you guys. Did a transmission filter change and got rid of the black fluid put fresh type f. And she drives good. Took her on a ten min ride wear I put gas down lightly and gas down heavy and got up and went . Little slow when I put on it . But she climbs . And no leaks. Filter I needed ended up coming from a 1970 model trans instead of a 1975 is that common. And thanks guys your info paided off a lot . So glad I brought it up in the forum
Old Jan 29, 2015 | 08:48 PM
77&79F250's Avatar
77&79F250
Glad to hear you got it up and shifting for less that a complete rebuild. Did you do a band torque check since you were in there?
Pheadrus
Mar 27, 2018 02:00 PM
RainyDay
Nov 23, 2009 11:38 AM
ford390gashog
Jan 5, 2004 12:28 AM
76390FE
Dec 11, 2003 12:57 AM
karljay
Mar 20, 2001 10:51 AM
