Transmission
Old Jan 26, 2015 | 08:02 PM
Tcook1687's Avatar
Tcook1687
Transmission
I just bought a 75 Ford F-250 runs great. Lost forward movement when driving it to my apartment after purchase . And it had dumped fluid a couple of times . Previous owner installed a auxiliary oil cooler . What could cause this and where could I look to fix it . 1975 ford f250 360 motor c6 trans
Old Jan 26, 2015 | 08:30 PM
HIO Silver's Avatar
HIO Silver
This is probably overly obvious but verify the tranny's fluid level.
Old Jan 26, 2015 | 09:58 PM
51M1's Avatar
51M1
Park it on the street till you confirm it isnt leaking. Tranny fluid is a bitch to clean up. Park on gravel if possible.
Old Jan 27, 2015 | 05:20 AM
Tcook1687's Avatar
Tcook1687
I have parked it. Just wanted to know where all should I check for leakage. I'm not fimiliar with the c6 transmission . I've owned a 84 ford ranger and 87 ford 150 both were manual transmissions . I'm new to working on automatics
Old Jan 27, 2015 | 11:09 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I take it had the correct amount of fluid before the test drive? And it worked fine on the test drive?
Dumped fluid from where? Where does it appear to be leaking from?
Did you get a 30 day handshake warranty or more like a "tail light" warranty (when the PO can't see the tail lights anymore), the warranty is over?
X2 on ck the fluid properly, but ck it first before trying to drive it anymore. Park it on level ground and follow the instructions on the dip stick.
Hot, in park....read the hash marks. Worse case before you take it to a trans shop, do a fluid and filter change.
Old Jan 27, 2015 | 07:06 PM
Tcook1687's Avatar
Tcook1687
Dumped fluid from the passenger side of the
Old Jan 27, 2015 | 07:31 PM
Tcook1687's Avatar
Tcook1687
It appears that have came from a old line between transmission and transmission oil cooler line. On passenger side. And warranty was tail lights which is fine it's not my primary driver any way so I can work on in my free time. The fluid that came out is black. So any pointers there would be great everyone is telling me I can't change the fluid or it will not drive agian.
Old Jan 27, 2015 | 07:50 PM
77&79F250's Avatar
77&79F250
the....?
Did you buy it with a good transmission or a questionable one? Might not matter now, cause you are paying for the work for sure.
Black fluid is burnt fluid can ='s bad news. I'd change the filter, flush it ...and the converter, and the cooler, slack ck the bands and button it back up and hope for the best.
Old Jan 27, 2015 | 08:06 PM
Tcook1687's Avatar
Tcook1687
the....?
Thanks . Final questions where can I get the vin number decoded and how many qts are fill up and can I add the Lucas transmission fix as well
Old Jan 27, 2015 | 08:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Post your VIN, in fact post your complete warranty plate (metal plate riveted to the driver's door) and I can decode it for you.
No idea on C6 capacity, I'm 1400 miles from my shop manuals right now.
Old Jan 27, 2015 | 09:25 PM
77&79F250's Avatar
77&79F250
Like mikeo0o0o0 said, post it here and he will decode it.
1. If the converter is dry then these will hold about 10 qts. If the converter is not drained and you are dropping the pan put 5 quarts in and check it. Depending on how long the pan is off it could take up to 7 quarts. You just have to add fluid a half quart at a time after the inital 5 quarts.
2. The C-6 also has a very large fluid capacity at 24 pints, including the fluid in the torque converter. 24 pints ='s 12 qts.
3. I looked in my 1979 Ford Truck shop manual on draining and refilling the C6 and it says to add 3 quarts of fluid after you remove the pan, drain the old fluid, and re-install the pan. My Haynes manual for '73-'79 Ford Trucks says to add a little fluid at a time since fluid capacities can vary and to use 4 to 5 pints as a starting point. Don't forget to use a new gasket.
4. Just dropping the pan and changing the fluid and filter. I'd start out with 4 quarts, start it up, then fill to level.
Old Jan 28, 2015 | 04:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6 = Approx. 13 quart capacity. 1966/76: Type F / 1977/ Mercon.
Old Jan 28, 2015 | 08:48 AM
Tcook1687's Avatar
Tcook1687
F25YCW26592
Old Jan 28, 2015 | 06:28 PM
NumberDummy
F25YCW26592
F25 = F250 2WD Pickup.
Y = 360 2V
C = Oakville Ontario Canada Truck Assembly Plant.
W26592 = 1975.
Trucks assembled in Canada were also sold in the US, could have been ordered by the Atlanta & Pittsburgh Ford district sales offices, possibly other offices as well.
DSO code stamped on the 3rd line-far right of the Warranty Plate, will decode to the office your truck was ordered from.
If 14 = Pittsburgh, if 21 = Atlanta. If another code, post what it is.
Old Jan 28, 2015 | 08:29 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Good evening Bill, I see you beat me to it .
Long day at work. Had to sit out yesterday because of the blizzard.
