Radio Issue
Old Oct 31, 2019 | 03:38 PM
FONRDAY's Avatar
FONRDAY
that does not work on 17
Originally Posted by Sterling6.7
Disconnect the batteries and turn the headlights on for about 10 minutes. This gives it a good drain and forces a reset. I had similar issues about 16 months ago, did this and no problems since.
It wont let you turn headlights if no voltage is detected it has a battery back up to retain info stored in computer
Old Oct 31, 2019 | 09:43 PM
Sterling6.7's Avatar
Sterling6.7
Getting light wasn’t the point. Draining the electronics is. Regardless, it works. There are settings that the PCM(?) battery doesn’t retain and also resets the TCM, because the learned patterns are gone. I’m not up on the proper names, but there are technical names for the levels of computer memory.
Old Oct 31, 2019 | 10:17 PM
FONRDAY's Avatar
FONRDAY
it wont drain if lights wont turn on
It wont let your turn lights or etc if no battery are present
GeorgeS59
Feb 15, 2018 09:30 PM
pchelp
48
Sep 1, 2017 10:34 AM
ncuffin
Sep 5, 2007 03:49 PM
ndakotan
May 11, 2005 11:36 PM
