Going to the dark side ...
Old Jan 14, 2015 | 12:04 AM
F-250 restorer's Avatar
F-250 restorer
I found a 1848 Holley for a good price and decided to buy it. Is there anything I need to know when rebuilding? Do the throttle shafts wear out? Should I check for that? Is just a simple rebuild kit all I need?
I'll have it as back up.
Old Jan 14, 2015 | 08:03 AM
AbandonedBronco's Avatar
AbandonedBronco
I know for me, whenever I get a used carb with an unknown age/condition, I simply buy a new base plate. It's a little expensive (about $100), but it's about the only part of a carb a rebuild won't fix, and worn throttle shafts cause nightmares.
There are nylon sleeves that come in rebuild kits for throttle shafts, but I've never had much luck with them, and have read most others don't either.
Other than that, just pull it apart, clean it up, and put it back together with the new stuff. Nothing fancy aside from just remembering where everything goes. Holleys are very screw/bolt in place and nothing really moves. Aside from the idle and such, adjustments are done by changing parts, so there's not a lot things you can accidentally mess up.
Just keep track of the check ball / weight underneath the accelerator pump squirter. =P
jjurva!
Feb 20, 2013 06:51 AM
teardropty
17
Nov 26, 2012 06:18 AM
beermonger
1978 - 1996 Big Bronco
Apr 13, 2011 03:43 PM
jthorngate3
Aug 20, 2010 07:07 PM
pward76
Jul 25, 2003 07:43 PM
