1978 - 1996 Big Bronco
Carb. ID
Old Apr 13, 2011 | 01:16 PM
beermonger's Avatar
beermonger
Carb. ID
looking to get a rebuild kit for the carb, how do I know which one to get?
All I know is its a holly 4bb, and is long overdue for a rebuild.
87 Bronco E.B. 351w
Old Apr 13, 2011 | 02:42 PM
beermonger's Avatar
beermonger
ok, its a 4160, and the renew kit is 37-119. my next question is how hard is it to rebuild, is there any special trick to it ?
Old Apr 13, 2011 | 03:36 PM
82_F100_300Six's Avatar
82_F100_300Six
I rebuilt an 1850, I'd rather rebuild a Holley than a Carter YF anyday.
make sure you get the accelerator pump to work before you turn it off anywhere other than your house because it likely won't start w/o prime.
some of those paper gaskets are terrible that are old and impossible to get off.
Old Apr 13, 2011 | 03:43 PM
AbandonedBronco's Avatar
AbandonedBronco
The renew kit 37-119 is the one I get for my 4160 4bbl.
Rebuilding a Holley is pretty simple. The only trick is getting the metering plate off since the screws aren't your typical phillips or flathead. Kind of an hourglass shape (can't remember the name). If you have the right width flathead, it'll fit (I bought a cheapie and ground the sides down until it fit).
Of course, you may already have the correct bit in your arsenal.
The other difficult part is installing the new nylon bushings around the throttle shafts. You need to remove the throttle plates to do it, which can be a pain to get back on straight (and they won't close properly if you don't). Mark where the screws are centered super well before loosening them.
The rest of the rebuild is VERY straight forward and easy to do. Disassemble as per instructions. Clean. Install new gaskets. Reassemble. I like to get a can or two of compressed carb cleaner to help with the job.
