Carb Rebuilder?
Old Jan 24, 2013 | 09:33 PM
jjurva!'s Avatar
jjurva!
Carb Rebuilder?
I am looking for a good and relatively inexpensive carb rebuild shop to send my holley 2300 to. Does anybody know a good place to send a carb to get rebuilt?
Old Jan 25, 2013 | 07:11 PM
LxMan1's Avatar
LxMan1
You can try here, Carburetor, Carburetors, Carbs, Carb Parts. Pony Carburetors - Your Ford Carburetor Restoration and Part Sales Specialist not sure how "inexpensive" it will be.
A local mechanic may be a better bet on a budget. Plus they can adjust it on the vehicle.
Those are pretty simple to rebuild, not a lot of parts if I recall.
Old Jan 25, 2013 | 09:04 PM
jjurva!'s Avatar
jjurva!
I have already put a kit in the carb only to figure out that the throttle shaft is very worn and the accelerator pump screws are partially stripped. I don't know how to re bush throttle shafts and I think a shop could do a better job of re tapping the threads for the accelerator pump screws. So hopefully I can find a shop that will rebuild the carb for a good price. Thanks for the recommendation!
Old Feb 18, 2013 | 04:20 PM
hotstuff's Avatar
hotstuff
location ? There are some good shops around the lower 48 ,there are bushing kits you can buy .
Old Feb 18, 2013 | 10:02 PM
tasboj's Avatar
tasboj
I feel you I had the same problem,I still have the same issue with the throttle shaft,but the screws for the accelerator I re taped with the next size up 10/32 prety eazy to do, and this morning I found a bush kit with reamer for 79.00 on jegs I think I'm going to order.
Old Feb 19, 2013 | 08:45 PM
jjurva!'s Avatar
jjurva!
LMC Truck has remanufactured carbs for 250.00 with a 45.00 core. It sounds like a pretty good deal. I just don't know how extensively these carburetors have been rebuilt.
Old Feb 19, 2013 | 08:59 PM
jjurva!'s Avatar
jjurva!
I just called LMC and the representative wouldn't give me any information about who or how they rebuild their carburetors. Looks like I won't be going to LMC for a carb.
Old Feb 20, 2013 | 06:51 AM
hotstuff's Avatar
hotstuff
try Mikes carburetors and parts ,he is in Wa. You can look him up on the web. If you were closer I would rebuild it
barnacle
23
Aug 19, 2017 08:39 AM
PA F250
Aug 28, 2013 08:49 AM
teardropty
17
Nov 26, 2012 06:18 AM
daveengelson
Apr 7, 2004 09:55 AM
laynrubber
Jun 13, 2003 09:44 AM
