Differential question
Old Jan 21, 2015 | 09:18 PM
whitetmw's Avatar
whitetmw
Originally Posted by mototrig
I'm not meaning to hijack but I just had a question. My axle code is C1 (3.73 LS). I have a few dial indicators and feelers gauges, is there any way of visually inspecting the limited slip and gears for excess wear? I'm going to pull the diff cover off this weekend and do a fluid change.
Not without removing the differential from the carrier. Once removed, the abrasive and spacers need to be stacked and compacted, then measure to determine health.
If your not having any noise, and it will work on loose roadways such as dirt, water (asphalt), or gravel your probably good-2-go.
I'm against testing them on dry hot pavement, the probability of damage is too great without a heavy duty race set up (the toe/heel of pinion where it contacts the ring gear).
Old Jan 21, 2015 | 11:10 PM
mototrig's Avatar
mototrig
Thanks for the info. Since you explain the best way of testing is on loose ground I'm pretty sure my limited slip is functioning properly. Last month I was able to pull my toy hauler through the soft stuff in Glamis aired down in 2wd. Didn't loose traction while turning so I think I'm good
Old Jan 24, 2015 | 03:39 PM
purplewg's Avatar
purplewg
I checked one shop and he recommended another. I went to him and he is supposed to have a quote for me on Monday.
Old Jan 27, 2015 | 12:34 PM
purplewg's Avatar
purplewg
Ok, I ended up ordering a Detroit Locker from Summit. The installer was having a hard time getting a price from his supplier. I told him I will get the parts and you just install them. He said ok. Will run $375 for the install with me supplying the parts.
Old Jan 27, 2015 | 01:30 PM
JOHN2001's Avatar
JOHN2001
Put it in drive and get them spinning. That'll tell you what you need to know. I do not know if you can check that way or not but you can check backlash and all that good stuff. It doesn't net you anything though
With a locker installed you need to watch how sharp you turn, like if you're in your yard or someone else's. If you cut it too hard you'll rip up the grass... As me how I know. Hopefully you got a soft engaging locker otherwise you're in for a treat when it pops. My truck sounds like a 12 gauge going off under my truck... I get some funny looks when it happens
Old Jan 27, 2015 | 03:22 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I'll add to the recommendations of the helical gear TrueTrac. This is the traction control device that Spicer/Dana installed as original equipment in the Dana S135-S and S150-S axles. So if it is good enough for a 13.5K and 15K LB rated drive axle, it is likely good enough for a 9K lb rated axle.
With the OEM True Trac in my 4x4, I've never had to lock the front hubs. When I shift into 4LO, it is only for the gear reduction. The rear axle on my truck has never seen a loss of traction with the True Trac.
In my previous Ford, I had the friction disc limited slip... called Trac Lok. Big difference in performance between Trac Lok and True Trac. If you are going to open up your axle anyway, and can afford it, go with the True Trac.
Old Feb 11, 2015 | 05:46 AM
purplewg's Avatar
purplewg
Ok, my truck is in the shop having the locker installed. I should get it back Thursday. Putting all new carrier bearings and races in also.
Old Feb 11, 2015 | 06:29 AM
whitetmw's Avatar
whitetmw
Here is the thing just so you know.
You will not notice any difference than when it went in.
What you will notice, when needed, it will be virtually unstoppable.
They are very smooth, unnoticeable during regular operation.
Old Feb 11, 2015 | 06:39 AM
purplewg's Avatar
purplewg
Thanks, I had a Detroit Locker in a car years ago and never knew it till I took it in and the mechanic at the dealership came to me and asked, "who put the Detroit locker in your car"? My answer was, "Ford factory". lol
Old Feb 11, 2015 | 06:43 AM
JOHN2001's Avatar
JOHN2001
The noise level is dependent on which one you went with. Hopefully you got the soft engaging locker otherwise you'll be in my shoes when you least expect it..... It'll sound like a 12 gauge going off under the truck as I said above
Old Feb 11, 2015 | 11:50 AM
purplewg's Avatar
purplewg
Not sure. This is the one I purchased.
http://www.summitracing.com/parts/dtl-225sl56a
Really doesn't matter much to me. I will primarily be using the truck as a farm truck. With manual hubs I wanted the most rear traction I could get.
Old Feb 11, 2015 | 03:21 PM
Jesser02EX's Avatar
Jesser02EX
I can't wait to hear what you think of this unit. I've looked at the Tru Trac after hearing a lot of positive comments about it. The locker looks interesting too. Please report back.
Old Feb 18, 2015 | 12:25 PM
  #28
purplewg's Avatar
purplewg
Granted all I have done is drive the truck back and forth to work but so far I am really pleased with the Eaton Detroit Locker. This is the 100% torque and power to both drive wheels and not a limited slip. The only things I have noticed is one side will spin/slip on pavement if it has a little sand. I do sometimes hear a little pop in the rear when I back in and turn. That doesn't bother me a bit. I am really glad I decided on this unit even if it did cost me a total of around $1300 when all was said and done.
I live in Fla so snow and ice are not an issue for me.
bearster18
Jul 18, 2012 03:47 PM
skyfox10
17
Mar 16, 2010 09:39 PM
bshep
Mar 8, 2009 09:31 PM
notmmrw1
Aug 10, 2007 10:42 AM
Oil-Pig
Jan 13, 2006 09:30 AM
