1966 Ford non limited slip to Limited slip/posi
Hello everyone. My truck has the below axle.
17 = Ford 9 Inch / 3.25-1 / Non Limited Slip / 3300 lb. Rear Axle Capacity
If I wanted to make this a Limited Slip/Posi rearend what could I do? Just add the stock limited slip parts to this rearend?
Has anyone done this to the stock rearend?
Thanks guys and gals.
Chip
Chip
Chip
Chip
Ford once offered accessory dealer installed LS kits. In addition to the LS kit, there was another kit needed to change the pinion gears. There were several LS kits, depending on the size of the pinion bearings.
The LS kit consisted of: Case, Clutches (steel & lined), Axle Gears, Hub, Spring, ID tag, and misc bolts, a pin and lubricant.
B9AZ-4880-C .. Limited Slip Kit - Use with 2 pinion medium bearing differential.
C1AZ-4215-C .. Pinion Gear Kit.
Another alternative would be to install a Lock-rite or similar. It installs in your standard open center section and will give you an honest "locker" rear-end. No special tooling, and for that matter, great experience is required. ~$300 - $400 and a couple of hours later, your in business. I had one in my Bronco and loved it. Lockers aren't for everyone however......
blloyd29
1999 to 2016 Super Duty
03-28-2016 07:11 PM
