Rear axel code C1 limited slip???
Old Jan 12, 2006 | 08:53 AM
Oil-Pig's Avatar
Oil-Pig
I read somewhere that C1 is a 3.73 limited slip rear in the X if this is true does anyone know if the carrier is rebuildable or do I have to get a new one. If the C1 is indeed a limited slip mines clapped out. Anyone have an exploded view of the stock limited slip diff?
Thanks!!
Old Jan 12, 2006 | 03:12 PM
Monsta's Avatar
Monsta
Sit. Stay.
C1 is indeed a Limited Slip.
try to go to www.fordpartsonline.com they have exploded views that you can look at.
I'm quite sure the carrier is rebuildable.
Old Jan 12, 2006 | 03:25 PM
Oil-Pig's Avatar
Oil-Pig
Thanks for the reply
I called Ford in town and they list 2 different clutch kits for the limited slip? One is a 3 pinion and the other is a 2 pinion?
The link you sent just has one kit for alot less then the dealer just wonder if its the two or three pinion. I am prolly going to have to pull the cover to find out
Old Jan 12, 2006 | 05:09 PM
Monsta's Avatar
Monsta
Sit. Stay.
More than likely it is a 2 pinion but if you're gonna rebuild the whole thing I think you can swap over to the 3 pinion design. It is a lot stronger.
Old Jan 13, 2006 | 09:30 AM
VX-23 Hokie's Avatar
VX-23 Hokie
If you have a diesel, it's a 3-pinion. Gas = 2-pinion.
link https://www.ford-trucks.com/specs/2001_excursion_1.html
