Engine Assembly...
Old Jan 13, 2015 | 06:49 PM
Bonanza35's Avatar
Bonanza35
That's a very good price if the work was done right. Most any of us would want that. Are these Ford rebuilt heads? I would think all seals, seats and valves were replaced if so. You said cups so I didn't mention that.
Old Jan 13, 2015 | 07:35 PM
Jesser02EX's Avatar
Jesser02EX
All the machine work was done by a local shop, I can visit them at anytime to ask questions. I'll go and give the block a visual inspection this weekend to see what I might be dealing with.
FTE give me confidence that I can do this. I'll need to pull out my ford manuals and give them a read. Is there an online service I can join that will have the manual in digital format? I like to read at work and the ford books are larger then my work laptop.
Old Jan 13, 2015 | 08:26 PM
jgilrfr's Avatar
jgilrfr
there is no doubt the people here will get you through whatever you run into
Old Jan 16, 2015 | 06:22 PM
Christof13T's Avatar
Christof13T
AllData D I Y
ALLDATAdiy.com Leading Source of Factory Automotive Repair Information
Old Sep 18, 2015 | 07:01 PM
dadisbroke's Avatar
dadisbroke
Originally Posted by Walleye Hunter
I'd do it myself if I were you. I have only rebuilt a two engines in my days. One was my Cummins 400 hp in my old Peterbilt and the other was a GM 350 CI in a van. The mechanical portion is pretty straight forward and it makes for a good learning experience on your engine. The only downside I see is that since you didn't disassemble it that you are not familiar with the nuts and bolts. I used several bolt buckets, one for each stage of engine disassembly to prevent confusion of parts and to prevent those extra bolts at the end of the show.
Whenever I do my own I use a lot of Ziploc bags and label EVERYTHING! Makes reassembling less of a headache, lots more fun
Old Sep 20, 2015 | 12:46 PM
Jaime74656's Avatar
Jaime74656
Make sure you have all the required tools, and most importantly an engine hoist (crane) and stand! Work smarter not harder.
Is the thing clean? Most likely no, CLEAN it again as you go through the process!!
And most importantly RTFM, be sure you understand what your doing!!
Old Oct 18, 2015 | 01:51 AM
dadisbroke's Avatar
dadisbroke
Originally Posted by Christof13T
Did I read over the part where you said you have a manual?
Definitely that..
Very. Good. Calibrated. Torque. Wrench.
Plastigauge is your friend.
Assembly lube is cheap...
Is it clean enough before final assembly? No... it isnt... clean it again.
I say give it a go. Building an engine with the appropriate peripherals sized and supplied is just a sequenced assembly.
Every hour you spend on it will get it closer to getting finished, and will give you another hour of experience building an engine.
How do I make sure my torque wrench is accurate ? Can it be recalibrated or if it's outta whack is it time for a new one, mine's kinda old but sentimental
Old Oct 18, 2015 | 08:10 PM
crop harvester's Avatar
crop harvester
you can send it off or check it against known calibrated/newer unit.We weld two old/damaged sockets together for redneck test.
Cole Neese
21
Feb 3, 2014 12:52 PM
Mental
Dec 30, 2012 07:22 PM
nothercrash
Aug 18, 2010 08:36 PM
64fordf100292
Sep 1, 2007 06:59 PM
Hidome
Jan 7, 2003 04:00 PM
