1200$.......
Just got back from the machine shop with some good news, and some that I would definitely put much more towards the questionable category. My 77 400 block (MCC, but August of 77) has no cracks, and is only worn about .005" in the bores, and has never been overbored before. My rods are also salvagable. I'm pretty happy about all that, and am very glad to fiiiinally have some answers on this project.
What I'm not so thrilled about though, of course, is the price. The machine shop charged me 130$ to clean the block, cam, crank, rods and pistons, push out the old bearings and plugs, magnet check the block, check the rods for deformation, and measure and inspect everything. That sounded like a fair price to me (correct me if that's wrong), but the plan he put together for me for the rest of the engine, and it's pricetag, sort of knocked me back.
For a .030" overbore, recond. the rods (+ new bolts), all new bearings including cam (installed), a new crank (needed), new pistons and rings, the pressing in of those pistons, a new oil pump, freeze plugs (installed) and a gasket kit for the entire engine, and all the associated labor, he wants 1,200.90$.
Like I said, that was a pretty big suprise for me. I was thinking right around 750$ for machine work, bearings, and a crank kit, but I may have been wrong with that figure (and I wasn't including all the rest of the stuff in his price), so what I'm asking you guys is, is that a fair price for all that work?
Whether or not I go for this will be a seperate topic. I have 2 cracked heads, this is going to be a ton of money, but just give me your opinions on that price, and I'll get to the other stuff after that.
Thanks, AleX
I think he wants 520$ for all the machine work, which does sound reasonable, but another question I have is, with .005" wear, do I even need a rebore?
And to answer your questions, I'm trying to build a very durable engine that I can have fun with. I love to spin the tires and that's just how it is. I'm not trying to race the truck, and it needs to be an all season daily driver, but I like to have fun in it. I was very happy with the level of performance I got from adding a 4 barrel, performance cam, new timing set, and heavy valve springs, but wouldn't mind a little more (planning to do with some flat top pistons), but don't want to go as far as aftermarket heads.
