B codes or C codes
Old Jan 6, 2015 | 08:03 AM
nmlewis's Avatar
nmlewis
B codes or C codes
I have an 05 x that I am going to be towing a Travel Trailer that is almost 11K pounds. Should I get B codes or C codes?
I am going to be putting on Bilstein 5100s.
If I use C codes would dual shocks on the rear help with the harsh ride unloaded or use 5160s?
Old Jan 6, 2015 | 08:45 AM
Gene Horr's Avatar
Gene Horr
I have the B code in the rear and while I haven't towed that much weight yet I did just do a trip with about 1300# in the rear and have towed about 6000# with the rear empty.
From this limited experience unless you are planning on have a large load in the rear of the vehicle while towing the B springs should be fine but I would consider a rear anti-sway bar a necessity.
The ride will feel harsher no matter what you do. But it isn't that bad - about the same as a F250 unloaded. You will gripe about it for the first two weeks then afterwards you won't even notice it. I have the Rancho 9000 shocks installed and keep them dialed at the lightest setting for daily driving.
Things like proper adjustment of the load leveling hitch, rear anti-sway bar, and proper maintenance of the front end will affect your towing, not going to C codes instead of B codes IMO.
Old Jan 6, 2015 | 10:35 AM
RobRoss's Avatar
RobRoss
On my truck I went with SRW C codes, reason being is here https://www.ford-trucks.com/forums/1...ring-swap.html
Unloaded the C has a better chance to ride better because the secondary rate is later than the B.
Old Jan 6, 2015 | 12:29 PM
Gene Horr's Avatar
Gene Horr
In that case I may be missing something. I had assumed the B springs were the "normal" rear (3000#) and the C were the slightly heavier (3300#) ones. This was from a chart from an aftermarket supplier but the searching became a bit confusing as what a "C" is depends on which model year.
If the only difference is the point that the additional leafs engage then Rob is correct and the C should give a smoother ride without a payload.
Old Jan 6, 2015 | 02:03 PM
RobRoss's Avatar
RobRoss
All of my research was part number based, I found the drawings and studied them. The rate/load I mention is from those drawings. I have no way to tell exactly which part number went with which spring code. If someone had a vin from truck with C codes (singe and dual wheel) I might be able to confirm the code(s) to the part number(s). From reading here I applied the codes to my spreadsheet of part numbers.
I think there are two C code versions, single rear wheel and dual
SRW - 330 lbs/in primary, 651 lb/in secondary, 1781 lbs transition, 2780 lbs max load
DRW - 350 lbs/in primary, 730 lb/in secondary, 1800 lbs transition, 3626 lbs max load
B Code - 320 lbs/in primary, 670 lb/in secondary, 1650 lbs transition, 2999 lbs max load
I looked at my spreadsheet and I don't see anything in my findings with a max load of ~3300 lbs.
I had sent my spreadsheet to one of the moderators but never heard back...
Does that help?
Old Jan 6, 2015 | 02:40 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
That right there is most likely where your issues are coming from. Aftermarket supplied springs are rarely up to the same specs as Ford OEM springs. A large number of the aftermarket "X" springs are barely better, if at all, than the OEM "V" code's. Same for the rear aftermarket springs as well.
Tom (WE3ZS) actually just sent me the chart that floats around here every now and then as I am looking at potentially revamping my suspension from V's and B-mod's to X's and C's.
Originally Posted by WE3ZS
The following only applies to 4X4 EXs, the 2X4 rigs have coil springs up front. All EXs came from Ford with G code rear springs, the V-8 EXs all came with B (front B code is much different than rear B code, confused yet?) 4100lb, all V-10 EXs came with C code fronts at 4300lb and all PSD EXs had D codes at 4700lbs.
All the other codes discussed come from SuperDuty trucks (they came with springs that don't suck from Ford.)
Spring........Capacity.....Rate lbs/".....Max travel.....V-10 change.....PSD change
B (V-8)......4100lbs.......330 lb/".........5.02"...........-0.25".............-0.66"
C (V-10)....4300lbs.......350 lb/".........5.01".............0.00"............-0.37"
D (PSD).....4700lbs.......380 lb/".........5.14"...........+0.33".............0 .00"
S codes.....4000lbs.......370 lb/".........4.34"...........+1.22"............+0 .88"
T codes.....4400lbs.......390 lb/".........4.63"...........+1.42"............+1 .11"
U codes.....4800lbs.......410 lb/".........4.89"...........+1.60"............+1 .32"
V codes.....5200lbs.......430 lb/".........5.13"...........+1.77'............+1 .50"
W codes....5600lbs.......450 lb/".........5.34"...........+2.77'............+2 .52"
X codes.....6000lbs.......470 lb/".........5.54"...........+2.90"...........+2. 68"
W codes are from F-450s and X codes are from F-550s and other SD trucks with snow plow prep.
The above spring info has been gathered from posts here on FTE by "monsta" and "bruce1954".
I'd also recommend getting in touch with Junior from ATS (username ATS Junior) and see what he can do for you. Here's a blurb from the conversations he and I have been having via PM. I requested a rear spring similar to the C-codes but with some extra weight handling capacity for towing and here's what he suggested:
Originally Posted by ATS Junior
...I can offer you a C code for the rear of your truck but install an extra leaf in it with a slight re-arch to level the truck out. We offer this spring to a lot of guys who are looking for height along with extra capacity in the rear (you will see about 1,000 lbs more in the rear). Because we match the stock leaf steel thickness your ride quality will not suffer all that much. Will it stiffen up a little? Yes but no where near a ridiculous hard and rough ride...
...This wouldn't be a normal add a leaf. This will be a long leaf (longer the stronger) added to the pack. It will have the same steel thickness as the rest of the steel in the spring. Some companies give you a thick leaf to add to your spring and that thick leaf will actually take most of the weight because it's the thickest, what usually happens is that thick leaf will either get weak or it will break.
But to get back to your original question, the springs that we can offer will be a completely new spring with a leaf added to the pack with an entirely new arch put on the entire spring to give you the lift that you are in need of...
Hopefully some of that helps you out. I can say from personal experience that with the B-mod rear's the ride is not harsh, it's definitely more "trucky" than stock but nowhere near what I'd call harsh. Single Bilstein 5100's on all corners for me as well, duals out back is just asking to get pummeled to death (unless Cary has some trick rear setup up his sleeve). Not to mention I don't know where the heck you'd mount them, not exactly a lot of room to work with back there especially with the tank and exhaust.
I recently towed a friend's Duramax crewcab 4x4 on a 20' flatbed, I'd say the combined weight was smack dab between 10,200-11,500 lbs. With the B-mods out back and nothing else (no airbags, no RAS, no WD hitch) it made my truck squat so hard it was untowable. However, my rear bumpstops deteriorated long ago and I haven't replaced them yet. But the tires were rubbing on the fender flares. We had to load the truck on backwards (biiiiig no-no, I know) and take backroads at slow speeds to tow it safely.
I have no idea with you have a WD hitch, if not - get one. Tons of members here tow large trailers and they swear by them.
Old Jan 6, 2015 | 02:57 PM
RobRoss's Avatar
RobRoss
Keep in mind the load ratings in the above chart are GAWR and not max spring capacity. The #'s I quoted are max for each spring on a bench test.
Old Jan 6, 2015 | 03:14 PM
Krazee Matt
Veteran: Navy
Good catch, I was in a rush when I posted all that and meant to include what you mentioned. Thanks dude.
Old Jan 6, 2015 | 09:25 PM
Drunken_Unicorn's Avatar
Drunken_Unicorn
Krazee Matt,
Is there similar chart like that for the rear springs?
Old Jan 6, 2015 | 11:10 PM
Krazee Matt
Veteran: Navy
Originally Posted by Drunken_Unicorn
Krazee Matt, Is there similar chart like that for the rear springs?
That chart includes the rear springs, B & C codes are at the top. Does not include the F codes (08-12 IIRC) that are the same as C's I think.
Old Jan 7, 2015 | 12:16 AM
WE3ZS's Avatar
WE3ZS
No, the B and C codes on the chart are the stock fronts, Ford used the same letter codes for fronts and rears to avoid any confusion, see how well that is working out!
Rob Ross has done some great detective work on these EX/SD springs and has some very good spring info! Dig into his posts about these springs.
Old Jan 7, 2015 | 12:31 AM
Krazee Matt
Veteran: Navy
WTaF Ford... Had me fooled forever with that damn thing. Im just full of useless misguided information tonight.
Old Jan 7, 2015 | 09:24 AM
RobRoss's Avatar
RobRoss
Thanks Tom!
If you're buying new, my spreadsheet may help, if you looking for used then I think any SD springs (B, C-SRW, C-DRW, F, etc) would such an upgrade that you would be happy.
You may want to consider an adjustable shock, in general, if you have less spring rate you will need more damping and vice versa. The SD springs do have less primary where the Ex springs is more or less a fixed rate. In my case the adjustable shocks helped me dial in my ride and helped me balance the front to the rear. Adjustable shocks are only for compression and rebound, once the shock is moving, you have the same damping regardless of setting.
Old Jan 7, 2015 | 10:25 AM
nmlewis's Avatar
nmlewis
C Code
Thanks for all the input. I think I am going to go with c codes with an Extra leaf from Junior.
Now who sells 5100's that does custom valving?
Old Jan 7, 2015 | 08:33 PM
Krazee Matt
Veteran: Navy
Originally Posted by nmlewis
Thanks for all the input. I think I am going to go with c codes with an Extra leaf from Junior. Now who sells 5100's that does custom valving?
Good choice, that's what I'm getting as well. Extra 1000lbs capacity as well.
I got my valved 5100's from CTPerformance. However, after 18-mo I wish I had either gone stiffer or with his custom valved dual shock setup. Bit too little damping and rebound control for my liking. I didn't want standard aftermarket duals, I've ridden in several rigs with them and at city speeds they pummel you to death. Soak up high speed bumps with ease though.
Spool&Go
Jul 16, 2014 12:23 AM
Tinman27
Feb 24, 2014 11:14 PM
73ferdf250highboy
18
Jul 24, 2013 11:05 AM
Stolher
Jun 22, 2013 10:57 PM
nzirbel
Mar 12, 2012 08:32 PM
