HELP BAD TURBO?
HELP BAD TURBO?
Ok my 2001 f250 7.3 with 232k miles is making a weird noise that I believe is coming from the turbo. I know its not turbo surge because I get turbo surge in my 02 7.3 when towing heavy sometimes. The noise is constant and is while driving and accelerating but quites when I let off the pedal it sounds like a rattlesnake and gets quicker and more violent whith higher rpms. I imagine the shafts has play and the blades are scraping the housing. I havent checked the turbo shaft for play yet. How much play is ok? The only thing done to it is muffler and cat removed and 6 inch tip. No chips or intakes.
On the same website there is a turbo rebuild kit for cheaper than the cartridge. You just replace the bearings and other internals.
I think you only need the cartridge if the turbine shaft is wore out or the exhaust side fan is busted. My turbo shift and exhaust fan were fine at 174k when I rebuilt it.
is that harder than changing out the cartridge? I've replace turbos before but never taken them apart but they seem pretty straight forward. I'll be replacing the oil cooler gaskets and O-rings tomorrow so after that ill get down to the turbo shaft to check for play. if there isn't any play what else would i be looking for?
It's the same amount of work honestly. You have to take it completely apart and put it back together. The only difference is if you do the cartridge you replace the turbine shaft/exhaust fan and if you do the rebuild kit you don't.
As far as causes of surge.. Not super sure but I think it has something to do with an off balance of pressures between the intake and exhaust side of the turbo. I added an after market compressor fan that solved my surge problem. Don't ask me the science of it though cause I'm clueless lol
Smokin'
33
01-03-2007 11:51 PM
