Help!!!!!!!!!!
Old Jul 13, 2013 | 03:51 PM
charger6t9r's Avatar
charger6t9r
Help!!!!!!!!!!
Hey all, well Going on vaca in 2 weeks and low and behold my turbo is making a squealing sound at high rpm's. At idle is fine. Any experience and/or advise is much needed and appreciated. any info on what the noise could be. Is it serious, can I make the trip from Charlotte to Detroit, do I need to remove the stock turbo. Steps in doing so. Any expected headaches, where can i get parts,I'm in a jam here fellas. Thanks a million for anything that can help.
Old Jul 13, 2013 | 05:56 PM
xcite's Avatar
xcite
Are you sure it is the turbo? Check shaft play and end play. If the turbo blades are contacting any part of the housing it is serious and would need to be replaced.
Old Jul 13, 2013 | 06:45 PM
charger6t9r
Pretty sure it's coming from the turbo. The shaft can move slightly up and down but not in and out. I don't see any wear on the inside of the turbine housing. Isn't there another turbine on the other side of the shaft? The noise literally sounds like a bad pulley bearing but Its not any pulley's
Old Jul 13, 2013 | 07:24 PM
xcite's Avatar
xcite
Yes there is a wheel on the hot side to. does it spin freely? If it does not sure what to tell you could maybe be the turbo or something else. If it is the turbo I have an upgraded factory turbo I dont need anymore.
Old Jul 13, 2013 | 07:26 PM
xcite's Avatar
xcite
Do you have pyro and boost gauges and if so what are they reading?
Old Jul 13, 2013 | 08:08 PM
charger6t9r
pyro reads about 100 degrees at idle, boost is around 5lbs not sure ofthe rpm's.
Old Jul 13, 2013 | 08:12 PM
charger6t9r
how do i check the wheel on the hot side? would I need to mod anything with an upgraded turbo?
Old Jul 13, 2013 | 10:02 PM
xcite's Avatar
xcite
The only way to full check the wheels is to take the turbo apart and inspect it. Nothing needs to be modified for the upgraded turbo. It is a turbo that was upgraded by Russ here from this site. It is an upgraded compressor wheel and housing machined to accept it.
Old Jul 14, 2013 | 12:45 AM
charger6t9r
thanks for everything excite. Where do u live and how much do u want for the turbo? I am going to do more investigative work tomorrow to confirm its the turbo. If it is I will be needing a replacement and cant afford a new one. Maybe I can get it on before vacation.I live in statesville nc.
Old Jul 14, 2013 | 12:52 AM
charger6t9r
Any tips on removing this turbo? I have never removed one before? does the entire unit need to be removed from the hat to the exhaust?
Old Jul 14, 2013 | 03:43 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Dont necessarilly need to upgrade. Even if there is some damage it can be salvagable. You will have to get the turbo loose to pull the hat, or at least i did. But it should come off fairly easy. Then the hard part for me was getting the turbine housing off. From there check you play, but since youre that far might as well stuff a kit in it. I wouldnt run the 60-1 wheel unless youre running 15-20psi as it does sacrifice some low end.
Old Jul 14, 2013 | 05:18 AM
charger6t9r
Im probably gunna start in a couple of hrs. I heard you couldt buy kits for these anymore.
Old Jul 14, 2013 | 07:07 AM
charger6t9r
Well im looking at it. Intimidating it is. I just read i may need to raise my cab to get it out.Dont know if i'm up for that today, especially after an all night rain saturated the ground.
Old Jul 14, 2013 | 07:25 AM
charger6t9r
If i am only replacing/repairing the turbine wheel bearing, does the entire unit need to be removed from the intake including the hat to the exhaust?
Old Jul 14, 2013 | 07:28 AM
charger6t9r
After this i am turning my ip back down. I suspect the high egt's may have fried the journal bearing. If so......lesson learnt!!!!
