A no start thread
Old Mar 6, 2015 | 07:16 PM
  #91
onefarmer's Avatar
onefarmer
Originally Posted by DIYMechanic
One would think, wouldn't one....
I usually do them one wire at a time with the old one on there just because I don't trust myself to get them right if I cut all 5 wires loose at once.
I was thinking the same way. I did the wires one at a time. But with my luck on this thing who knows.
When the connector burnt out it took the pin in the gasket and the plug ins inside and out so I had to replace the under cover harness, the gasket and the outer pigtail
Old Mar 6, 2015 | 07:27 PM
  #92
DIYMechanic's Avatar
DIYMechanic
What you can do to narrow it down is to start it up and then unplug one plug at a time to see which one doesn't make a difference. Just be really careful. Those injectors run on 110 volts. The plug that makes the least difference is the one that contains the issue.
Old Mar 6, 2015 | 07:42 PM
  #93
onefarmer's Avatar
onefarmer
That makes sense, be like pulling the plug wires on a spark ignition engine.
I'm done for the night. I'll be back when I have more to report.
Old Mar 9, 2015 | 09:47 PM
  #94
onefarmer's Avatar
onefarmer
I took the truck back to the dealer today and showed them it ran without spending over 1K on injectors. They had no answer as to why they couldn't find the cps issue. I did have them run a diagnostic on it again(on their dime) looking for the cyl it's missing on. They said cyl 2 and 6 was bad and they were again blaming injectors.
I brought it home again and I will be looking to verify the missing cyl.
I did find it when it's missing it blows light colored smoke, I assume unburnt fuel. And it would come and go as it would run close to right and get bad again.
Old Mar 10, 2015 | 06:31 AM
  #95
DIYMechanic
Does it miss like that all the time or just intermittently? And it didn't miss at all before all of this started (when it died originally)?
Old Mar 10, 2015 | 09:15 AM
  #96
onefarmer's Avatar
onefarmer
The miss and smoke comes and goes and no it ran great before it died. It's like a bunch of things happened all at once. I don't get it!
Old Mar 10, 2015 | 09:53 AM
  #97
DIYMechanic
What does you idling fuel pressure look like now?
Old Mar 10, 2015 | 10:33 AM
  #98
onefarmer's Avatar
onefarmer
I'll have to check it. I'm also going to take my oil pressure gauge from the right bank and put over on the left and see if it's steady.
As a side note, I did find some injectors that a guy had rebuilt and then changed his mind and put in bigger ones. he says they are Rosewood rebuilds. Deal was too good to pass up so I grabbed em.
Old Mar 10, 2015 | 10:35 AM
  #99
DIYMechanic
Sweet! What are the specs on them? Stock rebuilds or are they a lot bigger? If they're much bigger, you may need to do some supporting modifications, but it just depends on what they are. Rosewoods are some good stuff. Jim knows what he's doing with these things.
Old Mar 10, 2015 | 10:52 AM
  #100
onefarmer's Avatar
onefarmer
He didn't specify but since he said he went bigger I assume they are stock. And stock is all I need. with my chip truck has all I want. When it runs anyway.
Old Mar 10, 2015 | 12:04 PM
  #101
cowmilker08's Avatar
cowmilker08
Have you ran the living crap out of it yet? It takes a good beating to get all the air out of the oil rails.
Old Mar 10, 2015 | 03:09 PM
  #102
onefarmer's Avatar
onefarmer
I beat on it pretty good on the way home. 10 miles Maybe I should just drive around for a day?
Old Mar 10, 2015 | 03:26 PM
  #103
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
It can take a long time. I've heard of up to 200 miles
Old Mar 10, 2015 | 04:17 PM
  #104
onefarmer's Avatar
onefarmer
WOW Since there was nothing wrong mechanically before. Maybe I'll put insurance back on and just drive it. I still want to check the pressure on that side first. Just need time to work on it.
Old Mar 13, 2015 | 05:22 PM
  #105
onefarmer's Avatar
onefarmer
I went out for a drive again. This time I noticed whenever it started missing there would be some kind of flutter in the intake. Got it back in the shop, took the intake "Y" off so I could hear each side. When it missed the right bank has pretty loud popping noise. Now I'm thinking an intake valve is seating and unseating, causing the intermittent miss. I did narrow it down to the second cyl on that bank. When it misses that one does nothing and when it runs good that one definitely loses power when injector is unplugged.
travismoore
15
Feb 11, 2016 05:16 PM
Atwitsend
Dec 4, 2012 08:41 PM
97XLT4X4
Sep 17, 2011 07:34 AM
valiant500hp
Jan 21, 2011 12:28 PM
GRECO
22
Mar 17, 2008 01:03 AM
