FUEL/IGNITION?
Old Jan 20, 2015 | 01:07 PM
  #91
Gembone's Avatar
Gembone
In the video it looks like the crank gear is slipping around on the crank due to a sheared key. Will need to replace that as well.
Old Jan 20, 2015 | 11:06 PM
  #92
chicknsuit's Avatar
chicknsuit
Key was definitely sheared off and I think the reason for it loosening and tightening while spinning loose was there was a tiny piece of metal wedged between the gear and the cam shaft, as I would spin it that piece would make the gear rise and fall.
Old Jan 21, 2015 | 06:56 PM
  #93
JEFFFAFA's Avatar
JEFFFAFA
Woodruff key part number 358985-S. None shown on any of my parts locators. Used off another FE or parts store maybe?
Old Jan 25, 2015 | 01:48 AM
  #94
chicknsuit's Avatar
chicknsuit
Well I finally got it running. I still have to work on the choke adjustment. Thanks for all the input it was extremely helpful.
Old Jan 25, 2015 | 09:05 AM
  #95
orich's Avatar
orich
Hopefully it's the choke and not the exh. valves needing attentions. These old classic were built in the day of needing lead gas. And with out it, it slowly over heat the exh valves seats and burns away.
When putting the truck engine under heavy load like punching the gas pedal while going up a hill or passing another vehicle the engine starts to pop back through the carb.
Also a engine needing a tune up can also act the same.
Orich
Old Jan 25, 2015 | 12:16 PM
  #96
chicknsuit's Avatar
chicknsuit
I haven't driven it under those conditions yet. So that is something to think about this week for sure.
Old Jan 26, 2015 | 02:40 PM
  #97
Turbo Dog's Avatar
Turbo Dog
Glad you got it running
Hook up a vacuum gauge to manifold vacuum, if it is steady then the valves are sealing well. A single rhythmic dip comes from an exhaust valve that isn't seating, and a wandering gauge comes from poorly seating intake valves.
Truck looks really nice
Artemis Gentry
1983 - 2012 Ranger & B-Series
Jan 31, 2014 09:05 PM
1973F100Kid
Nov 17, 2011 12:04 PM
hemichrysler
May 17, 2011 03:15 PM
51dueller
Jul 3, 2006 03:41 PM
jdp7799
Nov 23, 2002 01:03 AM
