FUEL/IGNITION?
Old Jan 15, 2015 | 06:55 PM
351Cleveland C4's Avatar
351Cleveland C4
I don't think that's supposed to move but I've never tried.
Old Jan 15, 2015 | 07:15 PM
orich's Avatar
orich
It don't go in an not comes out keep looking.
Orich
Old Jan 15, 2015 | 07:28 PM
kenny nunez's Avatar
kenny nunez
not running
The rotor should "spring" in the direction of rotation which is cou ter clock wise.
It also could be a bad resistance wire that powers up the coil. I have seen them in the past where after they get hot the voltage goes away. You should have at least 8 volts when the engine is running measured at the "BAT" terminal on the coil. You should have a good spark from the coil wire when holding it 1/2" to 3/4" away from the manifold when cranking.
Old Jan 16, 2015 | 11:07 AM
chicknsuit's Avatar
chicknsuit
I bought carb rebuild kit yesterday and its been soaking all night. So if it doesn't fire up today after rebuild and new coil, new cap and rotor, new fuel pump & inline filter, new plugs I will be at a dead end....
Old Jan 16, 2015 | 02:35 PM
chicknsuit's Avatar
chicknsuit
Plugs, cap and rotor, coil, fuel pump, inline filter and rebuilt carb and it still won't start. Does this type of electronic ignition go bad?
that's all I can think of
Old Jan 16, 2015 | 02:41 PM
JEFFFAFA's Avatar
JEFFFAFA
No dead end yet. If the carb rebuild no help it just means more diagnosing.
I don't mean to insult you but since I don't know you yet I gotta ask, You did take the carb apart and are soaking just the metal parts....right?
We'll take the place of Good Ol' Pops the best we can. Hang in there Buddy.
Old Jan 16, 2015 | 02:45 PM
chicknsuit's Avatar
chicknsuit
Yes I took it apart yesterday, soaked just metal parts overnight and reassembled today.
Old Jan 16, 2015 | 02:54 PM
Tedster9's Avatar
Tedster9
That is a Pertronix Ignitor. They are excellent, tho (just like points) if the key is left in the RUN position with engine not running, the coil and module can be damaged. Make sure the mag ring is fully seated and the gap is approx .030
Old Jan 16, 2015 | 03:02 PM
chicknsuit's Avatar
chicknsuit
Is the map ring the plastic piece that sits over cam? where would I check for a .30 gap?
Old Jan 16, 2015 | 03:05 PM
Tedster9's Avatar
Tedster9
Yes, it's a slip fit over the distributor shaft, and the body of the module and the mag ring should be .030 in. apart. Not a major deal, just something to check. You should check the coil for proper ohms on the primary and secondary windings, at least. Substitute a known good coil if possible.
What coil is installed now? If it has an internal resistor, you would want to bypass the truck's "pink wire" resistor. If not, not.
Old Jan 16, 2015 | 03:09 PM
351Cleveland C4
Also check ignition timing. It needs to be somewhere around 10*.
Check and make sure your not 1 wire off, or even 180* off.
Old Jan 16, 2015 | 06:27 PM
chicknsuit's Avatar
chicknsuit
I just checked wires and they are all good however when turning it over and moving distributor clockwise it fires up but can't get it to stay. Wires are definitely in the correct order....?
Old Jan 16, 2015 | 06:43 PM
  #28
JEFFFAFA's Avatar
JEFFFAFA
Ah Ha! I was right in post #13. There is a bolt and a rather triangular shaped retainer clamp at the base of the Dizzy. Hopefully there is a Ford retainer clamp there and some wingnut didn't put just a washer there. Get yourself a "distributor wrench" to tighten that bolt and a timing light.. I believe Sears still carries them. Ford is the 1/2" size. (GM is the 9/16). Mark the timing marks with chalk or white paint. Have a Buddy start it for you while you holding the Dizzy. Get it started and then finish timing it. Then tighten that bolt. Double check the dizzy won't spin and fire it up and double check the timing.
Old Jan 16, 2015 | 06:57 PM
  #29
orich's Avatar
orich
I don't see the your ground wire inside the dizzy. It's a braided type little uncoated no insulation on it. I see an empty screw thread hole in the dizzy plate? Maybe it's not in the photo is one there???
Yes those unit can go bad. You should not have more then a .030 air gap from magnets rotor to the pickup unit. And no closer then .008 incase of a warn upper bushing so the rotor won't hit the pick up unit..
I setup up mind at .010 air gap when I was running one of these units.
Voltage from key to coil no less 8volts.
Orich
Old Jan 16, 2015 | 07:11 PM
  #30
Tedster9's Avatar
Tedster9
Yeah, where's the ground wire? That'd do it.
http://www.pertronix.com/support/man...itor12vneg.pdf
