FUEL/IGNITION?
Old Jan 19, 2015 | 09:58 PM
  #76
chicknsuit's Avatar
chicknsuit
This is what I found when I removed timing chain cover.
Old Jan 19, 2015 | 09:59 PM
  #77
chicknsuit's Avatar
chicknsuit
In addition to that here's a link to video I posted on you tube. You can hear my a ha moment towards the end. It explains everything!
Old Jan 19, 2015 | 10:26 PM
  #78
orich's Avatar
orich
Aw you found a chewed up oil slinger , Geez never saw one do that. It looks like it was put on backwards. By a shade-tree fix it guy who did not have a manual or how it's put on right. So much for someone's Photographic memory!
Orich
Old Jan 19, 2015 | 10:44 PM
  #79
chicknsuit's Avatar
chicknsuit
after watching video, how hard is it going to be for me to get cam and crank lined up?
Old Jan 19, 2015 | 10:49 PM
  #80
351Cleveland C4's Avatar
351Cleveland C4
Hmm, yep, that'll do it. Double roller timing set didn't look like it was in too bad a shape, unless the loose position is where it goes. Then it should be replaced. I think there is supposed to be a spacer behind the crank sprocket to keep it aligned. Or maybe it got put on backwards? Does one side have a offset shoulder?
I'm kinda puzzled why it was getting tight then loose. With it not turning that must mean the front of the crank is bent?
Old Jan 19, 2015 | 10:50 PM
  #81
351Cleveland C4
shouldn't be too hard. Set the crank to 12 o'clock, cam to 6 o' clock.
Old Jan 19, 2015 | 10:56 PM
  #82
orich's Avatar
orich
Ez have it line up the turn it over to make sure it is correct. Use a ruler as a straight edge centering the keyways and the 0 to 0 marks cam * is facing down like 6O:clock
The crank (*) faces up like 12: O'clock
Orich
Old Jan 19, 2015 | 11:00 PM
  #83
chicknsuit's Avatar
chicknsuit
351 I was thinking the same thing...it might be bent?
Old Jan 19, 2015 | 11:10 PM
  #84
orich's Avatar
orich
The oil slinger goes in front of the gear, and it's dog dished. it was put on in revere.
That causes it to rub the chain.
orich
Old Jan 20, 2015 | 12:23 AM
  #85
351Cleveland C4
that's the only reason I can think of. Unless something else is totally out of whack.
Old Jan 20, 2015 | 09:42 AM
  #86
orich's Avatar
orich
After watching your video, I am not sure what's going on. Is the gear just turning on the crank shaft freely like no key on the crank?.
And that is one sloppy chain that looks like a double roller. I've heard about some guys having a loose Timing chain like your being new on this site. I'd also replace that crank key to.
Orich
Old Jan 20, 2015 | 09:50 AM
  #87
chicknsuit's Avatar
chicknsuit
Orch the key is definitely sheared, or broke off. I am concerned why the chain will loosen and tighten with the gear spinning freely. I suppose I'll better answer that once I remove it from crank
Old Jan 20, 2015 | 09:57 AM
  #88
orich's Avatar
orich
It may be stretched. Put a good new set on and go from their. Should correct the problem. And replace the eaten up oil sling.
Orich
Old Jan 20, 2015 | 12:31 PM
  #89
JEFFFAFA's Avatar
JEFFFAFA
This work computer won't let me see those videos. I am assuming you have a 360/390. If that's the case the Ford part number is B8A6310A.
NOS PARTS LTD shows two....972-937-2201.
NOS ONLY.........shows two....800-667-6659.
Old Jan 20, 2015 | 12:43 PM
  #90
orich's Avatar
orich
This is what the oil slinger is suppose to look like the spacer pushes it up against the crank gear.
This keeps the oil from flooding the front seal in the cover.
orich
