I was thinking........dangerous.......Working on the 5th wheel axles with the ez-lube hubs. Use a grease gun full of dawn....pump it in until all the grease is pumped out. Bearing is clean. Now pump in grease until only grease comes out. Now the bearings are lubed.........
Oooooooooooo! Heckuva' idea!
Ummmmmm..... NOPE!
If sand can improve the performance of a gasser, why not axle bearings?
Yea, sand would be better to clean out the old grease. Real fine sand.
I've bought 35-40 engines from them over the years. Great company that stands by their products. They will build it anyway you want and will even dino it for you!
Ummmmmm..... NOPE!
Pop
Roy, I think you misunderstand the buddy bearing idea....
They are for pushing out the water when you back the boat in the slip. Period
They in no way clean the bearings, nor pack them properly.
If you pump enough grease in there, you WILL blow out the seals, and set them next to your axle. Then you end up calling me to come get you, and bring you home from your trip
Actually I got a shop to rework the U bolts and I filed out the lower plates and now the diff is attached to the springs and rims/tires on. Tomorrow I will start playing on the front end. I'm a happy camper now
Evening Gang, 9* this morning at 0645. Cold most of the day. I did get to watch the race this morning; good race, last 30 or so laps were out standing!!
I did see his post in the 61-66 forum; told him that a friend of mine in Bend is one of teh best FE guys around here. Rick at Monkey Wrench Auto.
