2015 BS thread. Bring it!
Old Feb 23, 2015 | 08:37 AM
  #4186
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
My thermometer is frozen
Hi John........
Not a good sign.........
Old Feb 23, 2015 | 08:40 AM
  #4187
fabmandelux's Avatar
fabmandelux
Sure wish you guys would keep that cold up there....................lol
  #4188
SpringerPop's Avatar
SpringerPop
... and here I felt like we were having inclement weather: scattered showers and 48*.
"Into each life a little rain must fall..."
Mornin' all!
Pop
  #4189
kjvforme's Avatar
kjvforme
Morning Don, started work on another bug engine yesterday. This one had a oil pressure problem. Found a screw jammed in the oil pressure relief valve locking it in the open position. The guy I got the bug from said his wife drove it for five miles that way.
Old Feb 23, 2015 | 08:43 AM
  #4190
kjvforme's Avatar
kjvforme
The screw in the port.
Main bearing
  #4191
fabmandelux
Mornin' all!
Pop
Morning Marv! 48 deg? I assume you have your long johns on?..................lol
Old Feb 23, 2015 | 08:45 AM
  #4192
fabmandelux
Main bearing
That should buff right out!
Old Feb 23, 2015 | 08:53 AM
  #4193
kjvforme's Avatar
kjvforme
The crank is not that bad. The bearing didn't eat itself all the way. I'm thinking about sending it out to be polished or ground.
Old Feb 23, 2015 | 08:56 AM
  #4194
fabmandelux
Did you get the other engine running yet?
Old Feb 23, 2015 | 08:57 AM
  #4195
67nukeford's Avatar
67nukeford
Veteran: Navy
You can't blame me Pat, you have all the tropical weather and I've been left in the cold....
John, somebody up there left a door or window open, and let all that cold air down here!!!
Old Feb 23, 2015 | 08:58 AM
  #4196
67nukeford's Avatar
67nukeford
Veteran: Navy
Mornin' all!
Pop
Morning Marv. I'd take that weather!!!
Morning Rob. Sure did a number on those bearings!
Old Feb 23, 2015 | 09:00 AM
  #4197
kjvforme's Avatar
kjvforme
Yes sir up and running needs some carb and timing work but appears to be running well.
Old Feb 23, 2015 | 09:31 AM
  #4198
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Main bearing
You can Buff that out.......It'll be good as new.......
EDIT: Sorry.....I did not see your post Don......Great minds run on the same track !!
Old Feb 23, 2015 | 09:46 AM
  #4199
SpringerPop
Yea, but there's lots of downsides to living in close proximity to ten million others. The normally-nice winters draws 'em in like flies.
I don't go out as much as I once did, and then only mid-day or late evenings, just to miss the almost unbearable traffic.
"Ain't no such thing as a free lunch............"
Pop
Old Feb 23, 2015 | 09:48 AM
  #4200
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
Good morning Oregon and everyone everywhere else. 29, clear, sunny with 4 to 20 mph wind.
