Wicked Wheel Installation Gone Wrong - PLEASE HELP
Old Jan 12, 2015 | 01:29 PM
  #61
brettdacosta's Avatar
brettdacosta
Originally Posted by Pitcrw6
Good to hear u got it fixed. Does Joe have a screen name on here so we can send him some rep points?
Yup - and I'm planning on it for sure...
It's cuttn4fun - he's the man, man!
Old Jan 12, 2015 | 03:31 PM
  #62
cuttn4fun's Avatar
cuttn4fun
Hey Brett. I have been thinking of that teflon tape you used on the fuel pump. I am not sure if that stuff is rated for the diesel or not. Just a thought?
As for the turbo, the back hold down bolt was a lot looser than I tighten them to. I felt that was the real culprit to the leak as the o rings showed no sign of being pinched or damaged.
Hope it is still running good for you!
Old Jan 12, 2015 | 04:50 PM
  #63
brettdacosta
I didn't use teflon on the suction side as it was just a brass fitting over the plastic fitting. The only place I used it was where the discharge barb screws into the connection of the pump body. It definitely appears to be leaking at the inlet connection, and I tried to get the hose clamps as tight as possible without them letting go or crimping the inlet barb too tight. So I don't know. I'm gonna take it back off and run it with the pump free and see if I can't nail down where it's coming from.
Old Jan 12, 2015 | 06:22 PM
  #64
Bonanza35's Avatar
Bonanza35
Guys I like to here this kind of kindness. Cuttn4Fun, thanks for helping out a brother FTE'er. Reps sent. Use some diesel dope on the inlet side, let it set and if that's the problem it should be cured. God bless,
Bill97
Sep 17, 2018 09:32 AM
RRranch
13
Sep 8, 2009 11:29 AM
ponch37300
Nov 5, 2008 06:41 PM
PSD Bill
Nov 4, 2005 01:38 PM
Fordafied
17
Mar 30, 2005 09:54 AM
