a bit off topic question.
Old Jan 1, 2015 | 09:17 AM
tjc transport's Avatar
tjc transport
i ain't rite
quote: Do you have any particular goals in mind? Before buying parts, it's good to have a goal or objective.
Chris, my goals are a dependable good running engine that will last at least another 200k miles. and get better than the current 8-10 mpg.
quote: What color smoke are you getting at start up?
white, until it fires on all 8.
i know it has at least one bad glow plug, probably 2.
like i said before, i was not sure on the life expectancy of the powerstroke injectors. i just figured it was the same 1100-150k miles as the IDI injectors.
Old Jan 1, 2015 | 09:18 AM
fordman67's Avatar
fordman67
I have 332000 on mine
Old Jan 1, 2015 | 09:21 AM
tjc transport
i ain't rite
Originally Posted by 427 fordman
Tom, I'm not saying you need injector work either, but if it were me, I'd still have them checked means you are getting in there. That's up to you though.
i understand fully where you are coming from Darrin.
i am of the same feeling. if i am in there, everything is getting looked at. not just what is bad.
i would rather spend a couple hundred to know the injectors are still good than leave them be and guess.
not looking at everything while it is apart is kinda like putting a pep buys starter in and expecting it to last.
you don't change just the bad part, you make sure everything is in tip top shape before putting it back together.
unless you like tearing things apart every few weeks.
Old Jan 1, 2015 | 01:19 PM
Diesel_Brad's Avatar
Diesel_Brad
Unless you are getting a consistent white and blue smoke. or have a rough running engine, you injectors are fine.
Your issues are Glow plug related, Not injector
Old Jan 5, 2015 | 12:37 PM
tjc transport
i ain't rite
well, just got off the phone with Jim and he said pretty much the same all all of you did.
so i am going to wait until snow plow season is done in a month or two and then rip it apart and sent them out to him to give them a once over.
Old Jan 5, 2015 | 12:39 PM
DIYMechanic's Avatar
DIYMechanic
I don't see you regretting sending them to Jim.
Old Jan 5, 2015 | 01:09 PM
tjc transport
i ain't rite
the only thing i will probably regret in not doing it sooner, same with upgrading the turbo wheel.
Old Jan 5, 2015 | 04:36 PM
427 fordman's Avatar
427 fordman
Sounds like a good plan to me Tom. Jim will treat you right.
Mike8623
16
Mar 24, 2017 11:50 AM
MK_snipe
24
May 25, 2016 04:24 PM
4CFarms
Sep 15, 2014 12:51 AM
Jknapp79
Apr 25, 2012 01:51 AM
Crazy_Jim
18
Jul 4, 2011 11:11 AM
