Which Injectors??
Old Jul 1, 2011 | 02:52 PM
Crazy_Jim's Avatar
Crazy_Jim
Which Injectors??
Ok fella's, I need a little advice here..
I just turned 400,000 on the truck the other night, which gets me all giggly excited! However, along with that excitement comes the realization that a LOT of stuff is ready for replacement on the truck. I'm battling a slipping transmission, worn injectors, and worn glow plugs among other things.
I'm looking for advice on what injectors to run? The truck is an '02 F250 with 6637 filter, 4" turbo back, and a DP Tuner with 40T and 80E modes. I've been leaning towards some Beans stage 1's, but I'm curious as to whether or not they'll work in a basically stock motor? Also, will I have to send the tuner back in to Jody for a re-tune with the new injectors? Any other injectors you guys can recommend for my setup? The truck tows pretty much 50% of it's life, every night. Thanks!
Old Jul 1, 2011 | 03:03 PM
VegasFordSD's Avatar
VegasFordSD
I just recently put a set of Casserly (Full Force) stage I's in my truck. Everything else was basically stock, just upgraded to a t-500 hpop, but they ran fine before that too. You will need to send the chip back to Jody to reprogram for the single shot injectors however.
Old Jul 1, 2011 | 09:01 PM
joeyd61's Avatar
joeyd61
Full Force stage 1s here,and i tow quite abit as well and really like them...like vegas said, you have to have your chip reburnt for them
Old Jul 1, 2011 | 10:15 PM
farmb0y's Avatar
farmb0y
I had cass stage 2's with a 38R, made for a SWEET towing setup!
Did you get those miles off original injectors and tranny??
Old Jul 1, 2011 | 10:25 PM
Bonanza35's Avatar
Bonanza35
If you buy the injectors from Jody he will burn your chip for free.
Chet
Old Jul 1, 2011 | 10:37 PM
Crazy_Jim's Avatar
Crazy_Jim
Nice, so most of you are recommending casserly / full force then. Any specific reason? Or just because they're proven? The injectors Jody sells are also Casserly?
Old Jul 1, 2011 | 10:39 PM
Crazy_Jim's Avatar
Crazy_Jim
Not sure on the injectors, I'm assuming they've been replaced with 400k on it, I know they haven't been replaced for over 100k. The trans has had one rebuild on it as well, but it was a run of the mill shop I'm sure, it's always shifted funny since I've owned it. I'm not the first owner.
Old Jul 2, 2011 | 05:52 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i run swamps stage 1's but i also run their tuning. cass makes good injectors also. you also cant go wrong with beans its all good just pick what best suits you.....
Old Jul 3, 2011 | 03:42 AM
Crazy_Jim's Avatar
Crazy_Jim
Well they're all the same price for stage 1's, and all have the same specs. I think I'll order some casserly's from Jody and get some re-tunes out of it
Old Jul 3, 2011 | 12:04 PM
Bonanza35's Avatar
Bonanza35
Good luck and you should be real happy in what you receive. Let us know which sticks you get. 1's, 2's or hybrids. Chet
Old Jul 3, 2011 | 03:55 PM
comadvan's Avatar
comadvan
How much louder are the stage ones? and when are they louder?
See Im coming out of my Duramax in NOV and I already have my 7.3 that im working on and would like to do injectors while im doing glow plugs.. But the 7.3 is loud inside the cabin compared to the Dmax and after some of my trips towing that are 24hrs straight I dont want to be deaf.. But I want it to pull "like" my dmax.. I know I'm asking for a lot...
Old Jul 3, 2011 | 04:33 PM
jkidd_39's Avatar
jkidd_39
Beans injectors = Cass Injectors FYI..
Can't go wrong w/ any vendors mentioned.. I have two sets of stage one's. The fuel economy gain is well worth the price.. Give Clay at Riffraff a shout. He will take care of you
Old Jul 3, 2011 | 04:52 PM
Bonanza35's Avatar
Bonanza35
They are louder sometimes mostly at idle and slow moving. On the road you won't notice it. Buy some sound proofing. Theres a post on here somewhere. On the inside firewall and under the seats makes a big difference. Takes time but well worth it. The EX already has it. Good luck Chet.
Old Jul 3, 2011 | 09:46 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
I've got some Sureflows sitting in box that will go into mine in a couple months..........210/100s. Your trans definitly won't last with these.
Old Jul 4, 2011 | 03:08 AM
T8R's Avatar
T8R
Happy with my Casserly stage II's. The decision between stage II and Hybrids came down to the fact that my budget wasn't ready to build the whole fuel system to keep up with the hybrids.
I'm secretly hoping that by the time I'm ready for hybrids, I'll be building an Ex for the wife that I can put my stage II's in.
