Pid. Value help
Old Dec 31, 2014 | 09:58 AM
Collin Wersal's Avatar
Collin Wersal
Pid. Value help
Taken at operating temp. Only have sct to monitor until Friday. Should I be concerned about any of these values? New to this stuff and have a 14 hour road trip coming up. Thanks guys taken at idle
2005 f250 6.0. Just had egr delete, New oil cooler, hpop, ficm fixed, 3 fuel injectors replaced and blue spring upgrade. Also just changed oil and all filters including air.
Old Dec 31, 2014 | 10:19 AM
bismic's Avatar
bismic
Operating temp is 190 degrees coolant. If all yours will do is 172, then I would look into a new thermostat.
Old Dec 31, 2014 | 10:23 AM
Collin Wersal
It gets to about 180-185 when driving. Its also -11 out today so don't know if that would factor into it.
Old Dec 31, 2014 | 10:30 AM
WatsonR's Avatar
WatsonR
the Ford t-stat is 190 as Mark mentioned and if your only running 180'ish, then it may need replaced. The other numbers look fine.
If it's that cold, maybe put a piece of carb board between the radiator and condenser to bring it up a little. It will try to increase the temps above 185 by throwing extra fuel at it, your mileage will be in the can. The truck will run better if you can get it above 185.
Old Dec 31, 2014 | 10:43 AM
Collin Wersal
Is replacing the thermostat a pretty easy diy job?
Old Dec 31, 2014 | 10:51 AM
2006White60's Avatar
2006White60
It was -17* last night and the highest I saw was 184*, I am doing the cardboard thing till this spring.
Old Dec 31, 2014 | 11:32 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Here is a nice list of what the all PIDs should read: https://www.ford-trucks.com/forums/a...1&d=1364848489
The t-stat swap is a breeze on the '05 and newer trucks. Drain a couple gallons of coolant in a clean bucket. With the proper socket and extension you can get to the two housing bolts without removing anything. Once those are out, pull the top rad hose off at the radiator- being careful around the nipple for the small line next to it, it's easy to break. Pull the tstat and upper hose together. Notice the index marks (arrows) where the hose goes on the housing. Put the new Tstat on the hose with the clamp exactly in the impression it left on the hose and the index marks lined up as before. With the new Oring in the housing, (no sealant required) reinstall the stat/hose assembly and put the coolant back. Warm it up and check for leaks.
Old Dec 31, 2014 | 12:26 PM
Collin Wersal
so is ICP duty cycle the same as ICP on that list? It says 1.0 on the list for idle and mine reads .24. That was the one I was mainley concerned about. Maybe im reading into to much.
Old Dec 31, 2014 | 01:54 PM
Rusty Axlerod
That is a bit confusing. ICP is a voltage reading on the sheet, duty cycle is normally expressed as a percentage. There are also values for ICP in psi but they're in the 3-4 digit range. I don't think I have seen values for ICP duty cycle before.
The IPR has values for Duty Cycle reading in percent.
Key On Engine Off is 14.84
low Idle is 24
High idle is 40
Maybe it's displaying IPR duty cycle and the (.) is an anomaly.
Ford.Dude
Feb 17, 2017 06:10 AM
olfordsnstone
Aug 19, 2016 05:34 PM
evan1242
Jun 24, 2015 09:12 AM
CoalRollinX
Mar 16, 2013 10:27 AM
bdavis1369
Jan 20, 2013 12:53 PM
