6.0 Excursion eot & ect temps.
Old Mar 3, 2013 | 04:15 PM
CoalRollinX's Avatar
CoalRollinX
Today driving down the highway I noticed on my edge insight cs that my coolant temp. was at about 170-176 while my oil temp. was between 188-191
is this something to have a concern about because I heard if they are 15 degrees apart you may have head gasket problems. However on backroads and non-highway driving the ect and eot stay about 10 apart. Any suggestions?
Old Mar 3, 2013 | 05:58 PM
rob40cal's Avatar
rob40cal
Let the X sit over night for a cold soak, and check both temps before starting.
Should be withen a few degrees of each other and withen a few degrees of the outside air temp.
If that checks out good then I would install a new thermostat.
Your coolant temps should be at 190 when at operating temp.
Old Mar 3, 2013 | 06:05 PM
BLADE35's Avatar
BLADE35
Do this^^^^ for shure
Also need a new thermostat your running Cold I bet your MPG is Down because of it
If you have a ECT vs EOT spread more than 15* that normaly means Oil Cooler needs replaced BUT sometimes could be front cover/water pump issue
Do the recomended cold soak test and install new thermostat and lets see where you stand at that point
BTW OEM (FORD) thermostats are the best and last the longest
Iv tried a few diffrent brands and the Aftermarket ones always run Cold after a Summer going into winter there spring gets stretched in summer so FORD thermostat is the only way to go IMO
Old Mar 3, 2013 | 07:42 PM
CoalRollinX
How difficult is it to change the thermostat and what does it usually cost to do?
Old Mar 3, 2013 | 07:48 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Cost is prolly $30 for a new t-stat, as far as changing it out, I don't know if the Ex motors have the EPB sensor bracket on the t-stat housing, if they do it's an hour job just because you're forced to remove more parts. Not hard, just some junk in the way that needs clearing out. If your motor doesn't have a bracket on the t-stat housing it takes longer to watch the coolant drain than it does to change out the parts, two bolts one hose clamp and out it comes. Make sure the new t-stat comes with a new housing gasket.
Old Mar 3, 2013 | 10:53 PM
daddykitty's Avatar
daddykitty
when i did my t stat on my ex i had to remove one of the fuel lines going into the fuel filter housing. There was not enough clearance to move that ebp bracket around it. Easy job. You could always do the blue spring upgrade since you're right there anyways.
Old Mar 11, 2013 | 08:56 PM
CoalRollinX
Thanks guys, I am going to install the blue spring an t-stat hopefully this weekend and I will let you all know how it goes
Old Mar 15, 2013 | 10:21 PM
CoalRollinX
Did the install today the ects are normal now. The spring made a night and day difference. Should I check my fuel pressure or should it be fine with the blue spring? Btw thanks for the help guys
Old Mar 15, 2013 | 11:56 PM
vellingapa's Avatar
vellingapa
Originally Posted by CoalRollinX
The spring made a night and day difference. s
in what way did the spring make a night and day differences?
Old Mar 16, 2013 | 10:04 AM
Unrealo4's Avatar
Unrealo4
I think he might means the tstat.
Old Mar 16, 2013 | 10:27 AM
69cj's Avatar
69cj
If you re-installed the spring type hose clamp keep an eye out for leakeage. I had to put a worm screw clamp on mine.
hi-jacker
Jan 14, 2015 04:51 PM
351Cleveland C4
34
Jan 9, 2015 05:10 PM
glockholiday
Nov 30, 2014 07:20 PM
Subzero68
Jan 26, 2014 11:56 AM
mblanken881
Nov 27, 2010 07:33 PM
