I had no taillights on my truck when I got it. But I had this bracket in the parts box that came with it. It mounts on the left rear side of the frame and supports the left taillight and license plate frame.
I would like to use it on the truck, but I want a matching bracket for the right side. Does such a part exist? I can find neither in my Parts books.
Could have been an aftermarket part, but it does look Ford'ish.
It's got a Ford part number stamped into it.
Originally Posted by ALBUQ F-1
Is it an illusion, or do I see numbers stamped/cast into it at the right in the picture? I could swear I see 77- (upside down in the pic).
The part number is there. I looked it up and the books show the standard brackets for a pickup with a bed, not a flatbed. So, as with many other things, the part numbers for like parts are the same except for the prefix.
And like for so many other parts which are uncommon because it's for a flatbed, they are not shown in the parts books.
What's the part number? I have parts catalogs going back to the 1948 issue. I think I also have the "Green Bible" parts catalog. This part may have been used on earlier than 1948 trucks.
OK, I lied.
The part number for the left side bracket IS in the Text Catalog, but not in the Illustrations Catalog.
The number stamped on this part is 77 13469 - B
And I believe turn signals and right side taillights were options in 1951, so I would think there would be a matching right side bracket. But I can't find it.
Went out into the freezing garage and pulled my parts catalogs. Both the January 1951 and the January 1952 catalogs list the RH part, but it's not listed in the earlier catalogs.
Looks like you need to find part # 81C-13468. I checked on partsvoice.com and no luck.
I suggest posting a want ad on the Barn and HAMB. It's obscure enough that someone out there may have it. Lastly, with today's available technology, I bet a good machine/production shop can make a replica, albeit an expensive replica.
I'm guessing they're pretty rare, given only a handful of states at the time required a right side tail light.
Yes. It is shown for the state of Washington!
That's it! 81C 13468. I measured the left side bracket. It's 7.7".
Thanks Ilya. That number is not in my parts books.
