The cats are placed by the manufacturer according to exhaust temperature, which is controlled by timing (pcm), and egr function.
Moving the cat back is preferable to moving it forward. Moving it back will cause it to run cooler, which may affect your ability to pass emissions, but moving it forward, towards the engine, could cause it to overheat.
i just replaced my cat system,the replacement system goes from 2 cats to 1 and its made from catco and comes ready 2 bolt on..
please check catalytic-converters.com
