steering clunky?
Old Dec 29, 2014 | 06:35 PM
alvald83's Avatar
alvald83
steering clunky?
I just got back from a little camping trip. On the way home my steering would clunk everyone once in awhile when I would turn. It sounds llike it binds up alittle before releasing with a clunk. This is not good since I justhad the gear box replaced last year. I have a '69 F250 with power steering. Any ideas?
Old Dec 29, 2014 | 06:52 PM
HIO Silver's Avatar
HIO Silver
.. there's a full can of beer loose in the bed.
Seriously, have you crawled underneath and checked for loose/worn components? What about looked under the hood to see if anything is loose?
Old Dec 29, 2014 | 07:21 PM
Tedster9's Avatar
Tedster9
Also check king pins and wheel bearings, drag link etc for excessive runout or play.
Old Dec 29, 2014 | 07:31 PM
6t6merc's Avatar
6t6merc
And the rag joint.
Eric
Old Dec 29, 2014 | 11:55 PM
351Cleveland C4's Avatar
351Cleveland C4
Steering column bearings make that noise exactly.
Old Dec 30, 2014 | 08:46 AM
MIKES 68 F100's Avatar
MIKES 68 F100
++1 ON RAG JOINT
Old Dec 30, 2014 | 09:48 AM
willowbilly3's Avatar
willowbilly3
Originally Posted by MIKES 68 F100
++1 ON RAG JOINT
My first guess too.
Old Dec 30, 2014 | 04:42 PM
JEFFFAFA's Avatar
JEFFFAFA
4X on the rag joint.
Old Dec 30, 2014 | 06:31 PM
kenny nunez's Avatar
kenny nunez
Steering bind
Also check that the body mounts have not rusted away.
Old Dec 30, 2014 | 07:56 PM
alvald83's Avatar
alvald83
after further review, it appears that it is coming from the column. I drove it today. No noises on the way to work. On they way home, it started clunking only when I turned left. Then I did it one time to the right.
Old Dec 30, 2014 | 11:28 PM
abe's Avatar
abe
See if your front cab mounts are bad. My truck had binding and cracking when I turned . My body man knew what it was even without looking under the truck. He did a temp fix by jacking up the truck and driving a short 2x4 between the floorboard and the frame. This simple thing made the steering perfect. When I had the money and the parts he fixed it right. Good luck.
Heathnorrie51
Apr 5, 2019 04:19 PM
JMyers0901
Feb 25, 2013 05:27 PM
CooGAR
Oct 14, 2010 10:42 AM
scottlane
18
Nov 16, 2005 05:35 AM
elemint
Oct 14, 2004 08:56 PM
