Tran Troubles
Old Dec 29, 2014 | 05:42 AM
LAbronc's Avatar
LAbronc
Tran Troubles
I have a 96 5.0 with E4OD trans and my problem just started. The trans shifts fine but when I slow down its like the trans downshifts hard, only once each time I slow down. When this happens I can feel the gas petal move, I know this sounds crazy. Any body got any ideas????
Thanks,
Old Dec 29, 2014 | 08:34 AM
rla2005's Avatar
rla2005
The transmission is 100% electronic controlled, check for codes. Yes, you can have a stored code or Key On Engine Off (KOEO) test failure without triggering a Check Engine Light.
Old Dec 29, 2014 | 09:56 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My SWAG* is that you have a broken motor mount.
*SWAG = Silly Wild A__ Guess.
Old Dec 29, 2014 | 01:30 PM
Crewcabber's Avatar
Crewcabber
Do you feel a big clunk when you put it under load and let off? If so I would agree with Mark
LAbronc
1978 - 1996 Big Bronco
Jan 1, 2015 09:29 PM
THaven
Oct 9, 2011 09:16 PM
thefish1
Feb 23, 2011 09:24 AM
redman84
May 3, 2010 02:27 PM
JOHN CHAPPELL
May 15, 2008 01:55 PM
