1978 - 1996 Big Bronco
Trans trouble
Old Dec 29, 2014 | 04:42 AM
LAbronc's Avatar
LAbronc
Trans trouble
I have a 96 5.0 with E4OD trans and my problem just started. The trans shifts fine but when I slow down its like the trans downshifts hard, only once each time I slow down. When this happens I can feel the gas petal move, I know this sounds crazy. Any body got any ideas????
Thanks,
Old Dec 29, 2014 | 10:16 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My SWAG* is that you have a broken motor mount.
*SWAG = Silly Wild A__ Guess.
Old Dec 29, 2014 | 12:39 PM
Kemicalburns's Avatar
Kemicalburns
start with the basics, when was the trans fluid/filter changed last?
Pull codes?
Old Jan 1, 2015 | 09:29 PM
Encho's Avatar
Encho
The Southernmost Mod
Check the drivetrain parts, as Mark said, engine/transmission mounts, and the rear driveshaft. If all that checks, retrieve codes. Does the trans operate normally apart from that issue?.
LAbronc
Dec 29, 2014 01:30 PM
1997fordf350
Feb 4, 2014 09:01 PM
LUMBERMAN
Jan 14, 2008 09:19 PM
