1994 e4od trans issue
Old Feb 16, 2011 | 01:11 PM
thefish1's Avatar
thefish1
Unhappy 1994 e4od trans issue
I have a 94 f-250 with the e4od trans, seems to shift fine, but has no overdrive, and sometimes seems to slam into second or third gear, I replaced the mlps, and disconnested the batteries for about a half hour, but still does the same thing, also its is sometimes sluggish from a dead stop, other times it pulls strong, I am just about at my wits end with it does anyone have any suggestions?
Old Feb 16, 2011 | 09:31 PM
rla2005's Avatar
rla2005
Check for codes:Ford Fuel Injection » How To Run a Self-Test to see what the PCM thinks is wrong. Many times there can be a stored code without have a Check Engine Light on.
Warm up the engine and transmission then check for codes using the procedure outlined above, or purchase a code reader.
Old Feb 22, 2011 | 06:36 PM
thefish1's Avatar
thefish1
thanks for the reply, I had it to the trans shop, it has no codes,they told me it was just plain broke,but I was told there is a solinoid block inside the trans that is usually the problem, and it can be purchased for around 100.00 and is pretty easy to change, so I may try that,has anyone had any luck changing one?
Old Feb 23, 2011 | 08:26 AM
subford's Avatar
subford
Does your speedometer work OK and no problems when using speed control and the RABS light is never on?
Old Feb 23, 2011 | 08:32 AM
rla2005's Avatar
rla2005
IMHO if it was a solenoid issue you would have codes. The PCM looks for the proper impedance of those solenoids that make up the solenoid block.
Here is a link for how to test the solenoids with a DVM: E4OD Solenoid Test - FSB Forums
Old Feb 23, 2011 | 09:16 AM
subford's Avatar
subford
If you have 1st, 2nd and 3rd working OK then your shift solenoids are OK.
Those values in that link are not right for a 1994 E4OD.
E4OD Shift Solenoid Failure:
Old Feb 23, 2011 | 09:24 AM
subford's Avatar
subford
1994-1996 E4OD Solenoid Pack Resistance values:
Eric
Dec 25, 2018 02:13 PM
Conant7
Feb 17, 2015 03:55 PM
jatatkupak
Jul 12, 2009 03:09 PM
scmac53
Apr 21, 2005 06:40 AM
RLKBOB
Nov 6, 2004 10:29 AM
