Correct brake master cylinder
Old Dec 28, 2014 | 04:53 PM
aj3501's Avatar
aj3501
I have a 73 f250 highboy and have always had issues with the brake pedal not returning all the way which leaving my brakes lights on from time to time. does anyone have an idea as to which master cylinder I need for my truck?
Old Dec 28, 2014 | 06:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
More than likely it's not the master cylinder. Check your brake light switch. The way Ford retained the switch wasn't one of their better ideas. It uses a push nut kinda set up and the switch will gradually push through the little retainer sleeve allowing the switch to move away from the pedal and remain on.
New switches come with actual nuts that won't lose their adjustment.
Old Dec 28, 2014 | 06:31 PM
aj3501's Avatar
aj3501
Not the case here....I've tried taking off the one so it would extend farther but it wasn't very solid so I put both nuts back on and left it as you see in my picture
Old Dec 28, 2014 | 07:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Gotcha, do you have power or manual brakes?
Old Dec 28, 2014 | 08:12 PM
aj3501's Avatar
aj3501
Manual brakes
Old Dec 28, 2014 | 08:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Master Cylinder
'73 F250 4WD and drum brakes w/o booster 1" bore
before s/n R00,001
D3TZ-2140-M replaced by D3TZ-2140-N
from s/n R00,001 D3TZ-2140-N
'73 F250 4WD and drum brakes with booster 1" bore
before s/n S60,001
D3TZ-2140-A replaced by D3TZ-2140-P
from s/n S60,001 D3TZ-2140-P
McDonald Obsolete Parts, Rockport, IN has 1 each of the -N and -A (812) 359-4965
Green Sales, Cincinnati, OH has 21 of the -N (800) 543-4959
Bowman Sales and Service, Bowman, ND has one of the -P (701) 523-3257
Old Dec 28, 2014 | 08:22 PM
aj3501's Avatar
aj3501
Thanks, I'll try To get ahold of one
Old Dec 28, 2014 | 08:30 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Manual brakes
Okay, the one you want is D3TZ-2140-N
chrislynn5
13
Mar 7, 2016 09:15 PM
duhrbroc
Oct 11, 2012 07:39 PM
Brainard 66
May 19, 2009 11:20 AM
55FordLover
May 19, 2005 12:10 AM
faype02
Jul 27, 2001 09:49 AM
