2011 F150 keyless entry keypad
Old Dec 16, 2014 | 11:39 PM
Powerstrokin_350's Avatar
Powerstrokin_350
Hey all! The wife's got a 2011 F150 XLT with the stick on keypad under the exterior door handle. Tonight I noticed it's lit up red and after an hour it's illumination won't shut off. As well, it won't work anymore to lock/unlock the doors. Is it battery powered? Does the truck have an issue?
Old Dec 17, 2014 | 02:33 AM
j.grif's Avatar
j.grif
if it is the stick on kind, yes it does have batteries, you may want to remove the batteries and put them back in after a minute or two, from what I understand the stick on key pad is essentially a remote key fob in operation, do you also have remote keyless entry?
Old Dec 17, 2014 | 07:21 AM
Powerstrokin_350
I'll have to look into it and see how to check for a battery. Yes it has remote entry/start
Old Dec 17, 2014 | 11:01 AM
FordService's Avatar
FordService
Official Ford Rep
Hi Powerstrokin_350,
I checked out your Owner's Manual and didn't find a procedure for replacing the battery in the keypad; be sure to let us know what you find. Keep in mind you can always take the truck to your dealership as well. How many miles are on it?
Crystal
Old Dec 17, 2014 | 02:33 PM
Powerstrokin_350
It has 80,000 miles. Ya I checked and didn't see a battery or battery area anywhere
Old Dec 27, 2014 | 11:30 PM
Powerstrokin_350
Anyone out there know about the factory door handles with the keypad built in? Are they a wired in thing? Basically I was wondering if i changed the door handle for one with a keypad in it, is it a pita to get working if at all possible?
Old Dec 27, 2014 | 11:51 PM
j.grif's Avatar
j.grif
Yes, the keypad is wired in, it is possible that the harness is there inside the door, is it likely, I don't know, the other component to this is a module behind the rear seatback that is wired into the harness also, its possible that the harness details are there also, if they are, you would need the module and the door handle with the buttons, and possibly a reflash of the body control module or as Ford likes to call it the generic module. Do a search of How to remove rear seat back, pull the seat back and see if the harness is in there, am I certain of this? Not!
Old Dec 28, 2014 | 11:54 AM
Powerstrokin_350
Haha ok thanks! So if it's too much work, then in regards to the ford stick on one, it has no wiring then? it can be peeled off the door cleanly? Because I can't for the life of me see how I'll be able to get this thing apart without destroying it. If you use precision and patience and a tiny little set of screwdrivers, the keypad may pop out of all them tabs but im more of a attempt- break a tab- continue- break another- smash with a hammer and buy new kinda guy
Old Dec 28, 2014 | 12:05 PM
j.grif's Avatar
j.grif
LOL, take a picture and post it, if it sticks on, use a heat gun and fish line to unglue from the door. If the harness details are in the truck, you should be able to retrofit, otherwise, you can buy another stick on keypad from Ford.
simplywebb
2004 - 2008 F150
Mar 18, 2014 06:02 PM
1breezy1
1997 - 2003 F150
Sep 8, 2011 11:09 AM
utjer
May 22, 2010 02:20 PM
MustangGT221
Sep 13, 2004 12:59 AM
wilsonv10
Jun 22, 2001 07:41 PM
