front diff problems
Old Dec 13, 2014 | 09:34 PM
dgulledge's Avatar
dgulledge
Yes tires are the same size
Old Dec 13, 2014 | 09:37 PM
Yahiko's Avatar
Yahiko
You said that you already had it out.
Did you happen to take a look at he
spider gear set and how did they look?
Sean
Old Dec 13, 2014 | 09:42 PM
dgulledge's Avatar
dgulledge
While I had the front differential apart I inspected all gears and bearing everything looked good no broke or cracked gears no frozen bearings no metal in bottom of the diff housing.
Old Dec 14, 2014 | 11:10 AM
dgulledge's Avatar
dgulledge
so I went out and checked play in transfer which is only 1/2 inch but I did notice there was some damage to the front drive shaft at the flange could this be my problem?
Old Dec 14, 2014 | 11:28 AM
mhoefer's Avatar
mhoefer
Yup, is that on the transfer case end?
Old Dec 14, 2014 | 12:24 PM
dgulledge's Avatar
dgulledge
Yes it is. It's been like this since I bought it. I thank it's binding when it is turning giving the impression it's slipping. What should it look like?
Old Dec 14, 2014 | 05:15 PM
mhoefer's Avatar
mhoefer
Are the transmission and transfer case mounts all intact, something is binding that u joint severely. Motor mounts? It's possible someone had it off and put it back together wrong. I just cat see how it could be binding so bad in that u joint. Either that or your front axle is moving back? You need to be careful to look into this properly, something is very wrong and needs to be fixed properly?
Old Dec 14, 2014 | 05:41 PM
dgulledge's Avatar
dgulledge
I checked my buddy's truck 04 f250 just like mine his front drive shaft has a double yoke with the flange on one end drive shaft on the other. I thank they put the wrong drive shaft in it.
Old Dec 14, 2014 | 05:49 PM
mhoefer's Avatar
mhoefer
That could very well be, or it's out of sync by 180 degrees. Looks to be possible 1/2 inch or so to long to bind like that. Jheesh you can find the weirdest things heh?
Old Dec 14, 2014 | 05:54 PM
dgulledge's Avatar
dgulledge
Sure can it doesn't have the double yoke in it so I thank it's time to do a little cutting and welding
Old Dec 14, 2014 | 06:33 PM
Yahiko's Avatar
Yahiko
You could remove the shaft and take into the local
drive shaft shop and have then spin it up and
see what it does.
Sean
Old Dec 14, 2014 | 06:37 PM
dgulledge's Avatar
dgulledge
see what it does.
Sean
I just put the truck on jack stands and watched it while spinning it definitely the problem it has to be shorter for the h yoke to fit
Old Dec 21, 2014 | 03:30 PM
  #28
dgulledge's Avatar
dgulledge
So after an h yoke and a shorter drive shaft I now have 4 wheel drive thanks for the help
Old Dec 21, 2014 | 03:48 PM
  #29
mhoefer's Avatar
mhoefer
Awesome
farmerchad
2004 - 2008 F150
Feb 4, 2017 10:49 PM
radramrod2
Jan 7, 2013 11:34 PM
haybayian
Aerostar
Jun 9, 2008 01:55 AM
emptyd
Sep 19, 2007 05:00 PM
netscaner
21
Jun 14, 2007 09:01 PM
