Dtc
Old Dec 21, 2014 | 02:56 PM
bizzj's Avatar
bizzj
Dtc
Hey guys I got some dtc first time I hooked up the tuner and from what I read it is an exhaust circulation malfunction any ideas as to what I'm going to have to replace?
Old Dec 21, 2014 | 03:12 PM
mhoefer's Avatar
mhoefer
Give us the codes and perhaps we can help. We also need to know truck, make, model, year, mods you have done ect.
Old Dec 21, 2014 | 03:15 PM
bizzj's Avatar
bizzj
Ok I have a 2005 f250 Harley Davidson. I have had the heads milled and the arp studs put in blue spring mod and egr delete. The codes are p0403 p0405
Old Dec 21, 2014 | 03:27 PM
mhoefer's Avatar
mhoefer
Do you have am EGR delete kit? Both codes are low EGR flow, of exhaust in the he intake. It is taking MAP, Baro, EBP and IAT2 readings and finding no exhaust flow into the intake? So, two guesses, either your EHR valve is stuck closed, or EHR deleted? If you have it, try pulling amd cleaning? If you don't, to get the code issue dealt with you need a tuner to stop the codes. If you clean the EGR and it doesn't help, may need a new EGR valve but first things first.
Old Dec 21, 2014 | 03:32 PM
Money-Pit's Avatar
Money-Pit
Your EGR delete is causing those codes. Either buy an EGR valve and plug it in, then lay it on top of motor..... or buy a tuner to ignore EGR.
Old Dec 21, 2014 | 04:01 PM
bizzj's Avatar
bizzj
I do have the egr delete my ? Is will my truck be ok or do I have to get that plug right away?
Old Dec 21, 2014 | 04:06 PM
Money-Pit's Avatar
Money-Pit
The EGR valve needs to be electrically connected for proper fan operation. It can just lay in the valley.
EDIT: I didn't realize you already had a tuner, do you have the option to ignore EGR?
Old Dec 21, 2014 | 04:10 PM
Rusty Axlerod's Avatar
Rusty Axlerod
What kind of tuner do you have? It may be able to "turn off" the EGR or custom tunes are available for some models that will definitely do it for you.
Old Dec 21, 2014 | 04:24 PM
bizzj's Avatar
bizzj
I have an sct tuner and I'm looking now to see if it does I don't think so though
Old Dec 21, 2014 | 04:36 PM
87crewdually's Avatar
87crewdually
It won't hurt a thing. You'll just always have those codes, unless you do what I mentioned earlier.
Not having the EGR plugged in doesn't allow the fan clutch to function properly.
Old Dec 21, 2014 | 04:38 PM
87crewdually
SCT tuner should have the function to disable EGR so that it doesn't set a CEL.
Old Dec 21, 2014 | 04:42 PM
Money-Pit's Avatar
Money-Pit
You're absolutely right, I have corrected my mistake.
Nive catch!
Old Dec 21, 2014 | 05:03 PM
Yahiko's Avatar
Yahiko
But the valve still needs to be plugged in
the PCM looks for it. If not there you may get
some odd fan operations.
Sean
Marry Christmas
Old Dec 21, 2014 | 06:22 PM
bizzj's Avatar
bizzj
Does anyone know how to monitor the oil temp on an sct. I trekked and couldn't find anyone know what option it is?
Old Dec 21, 2014 | 07:01 PM
Yahiko's Avatar
Yahiko
You might have to use the data logging software package.
Never used it myself so I don't know for sure.
Sean
Marry Christmas
RenoHuskerDu
Jun 6, 2018 05:32 PM
JonArmy
Feb 5, 2012 08:22 AM
openexcess
Jun 12, 2011 05:12 PM
M.Farragher
May 19, 2010 10:03 AM
Xdrive
1983 - 2012 Ranger & B-Series
Jul 19, 2004 03:26 PM
