I am finishing the cab removal on my donor truck, and would like to keep the cruise. Is there a control unit for it, or is that all in the servo unit? I just want to get everything I need before I toss the cab.
Not sure what you mean by servo, but there's the module as I would call it to the right of the master cylinder that the cable runs through and the supporting electronics should be it.
It should be a little black box, with two connectors plugged into it, under the center dash area. It's held in place with two screws through it at the sides.
I'm sure you know better than me, but that sounds an awful lot like the delay wiper box - but then again, maybe it is a whole lot like it.
If you follow the vacuum hose back from the brake pedal switch, the harness for the cruise box should be taped onto it right near the box. It's down low in the dash kinda behind the ashtray.
