Door lock voltage issue
Old 12-09-2014, 06:38 PM
ztodd377's Avatar
ztodd377
ztodd377 is offline
Angry Door lock voltage issue
Hey everyone. Over the past couple of months my passenger door lock hasn't been working properly. I've preformed the door lock fix with the aluminum foil 6 or 7 years ago and tried it again recently thinking that may be the problem. No such luck.
I bought new actuators and replaced the passenger side one and same problem still. I then checked the voltage coming from the switch. Drivers door on lock and unlock sends 11.5V to the actuator. Passenger door on luck and unlock only sends 1.5V to the actuator. Where do I go from here? I've read something about door lock relays but no one seems to know where they're located. Any help is greatly appreciated!
Old 12-10-2014, 10:58 AM
ztodd377's Avatar
ztodd377
ztodd377 is offline
No one knows?
Old 12-10-2014, 03:24 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
I don't have a schematic available to see what's what but it could just be a bad connection somewhere in the feed to the switch.
Did you but OEM actuators? Will they work on the bench with a test battery?
Old 12-10-2014, 06:54 PM
petrokiller's Avatar
petrokiller
petrokiller is offline
Todd you need to pull the radio in order to get to the relays.
There behind and between climate control and radio on the firewall.
I used my key fob while reaching in and touching relay while lock and unlocking. You can here them with engine off.
Pretty sure if other doors are working the relay may be good. If anything mark them and then switch them around. See if volatage follows the relay.
If I remember right its 3 relays. Lock, Unlock, Horn and thinking about maybe 1 for the Parking lights flash.
If truck has keylessentry the lights blink and horn toots when double clicking lock on remote
Old 12-10-2014, 08:01 PM
Whitey Ford's Avatar
Whitey Ford
Whitey Ford is offline
FTE-Spread The Knowledge
Check the wire bundle coming in the door. The door plunger knocks it free and does very strange things.
Old 12-12-2014, 11:32 AM
ztodd377's Avatar
ztodd377
ztodd377 is offline
I searched everywhere, even behind the radio and didn't find any relays. According the Haynes manual our trucks either came with them (and RKE) and or didn't. I'm guessing mine was one that didn't. I pulled the old actuators back out, cleaned them up really good, added new foil and reinstalled. Seem to be working fine for whatever reason so I'm good with that. Thanks for all the help!
Old 12-12-2014, 12:49 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Might have been some corrosion on the connection and messing with it helped to improve the connection.
You are correct. The relays only occur on the RKE models. Here are the wiring diagrams in case you have the need later.
Old 12-12-2014, 01:44 PM
ztodd377's Avatar
ztodd377
ztodd377 is offline
Thanks for the diagrams!
Captain 'Murica
1999 to 2016 Super Duty
19
05-16-2021 12:12 PM
6_Myles
10-03-2010 09:58 PM
Saxon
12-31-2009 06:40 PM
Robot_2008
Aerostar
12-02-2008 02:20 AM
3BBB
1997-2006 Expedition & Navigator
01-03-2008 06:05 AM
Quick Reply: Door lock voltage issue
