Low Door Lock Voltage
Old Oct 2, 2010 | 05:03 PM
6_Myles's Avatar
6_Myles
Been having problems with drivers side front & rear doors, as well as the rear window lock. They unlock just fine, but won't lock.
I did the tin-foil trick on all three and it didn't improve any of the three actuators. I took a voltage reading at the drivers door and it was virtually nothing on the lock and a good 12v on unlock.
Could a bad actuator be causing this or is it the VSM, or a bad ground? It just started out of the blue.
Old Oct 2, 2010 | 07:38 PM
perryg114's Avatar
perryg114
Most likely it is a bad relay. There are actually three relays. All lock, all unlock, and driver unlock relays. So I expect your, all unlock relay, is bad. Most likely the extra current caused by shorting out the resistors in the door lock modules has caused the relay to fail. I don't know where the relay is. All I can tell you is follow the clicking noise.
Perry
Old Oct 3, 2010 | 08:43 PM
6_Myles's Avatar
6_Myles
I've got an 03 7.3L, and I've been reading that the Remote Door Lock is part of the Vehicle Security Module and it's behind the radio.
Can anyone confirm this? Thanks
Old Oct 3, 2010 | 08:51 PM
moto4's Avatar
moto4
Have you checked the voltage on the two that are working? It would seem strange that a relay would work for some, but not all.
Old Oct 3, 2010 | 09:58 PM
bgalaxy67's Avatar
bgalaxy67
How is the resistance in the ground circuit?
I found my ground wire worked it's way loose. It is on the drivers side behind the panel in the cargo area. It's closer to the second row shoulder harness.
2000PrettyBaby
1997 - 2003 F150
Dec 23, 2016 10:00 PM
Mr_CarMan007
Mar 4, 2016 11:52 AM
IIGood
Oct 26, 2015 05:35 PM
Nighteyez
Sep 18, 2013 12:52 AM
GRB1
Sep 9, 2009 06:29 PM
