Christmas gift help needed
Old Dec 8, 2014 | 02:24 PM
Nudnik's Avatar
Nudnik
So a lady I work with is trying to get a husband an awesome Christmas gift but doesn't know where to turn & I'm not sure what to tell her either. Her husband is restoring a 66 F100 but he needs a new firewall (I'm guessing rust damage). Anyways, does anyone sell replacement panels that include the firewall for a 66?
Old Dec 8, 2014 | 03:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-8106010-A .. Firewall / Obsolete ~ 1965/66 F100/250 2WD & 1966 F100 4WD
No Ford dealer or obsolete parts vendor has any and AFAIK, no one reproduces it.
Old Dec 8, 2014 | 03:56 PM
banjopicker66's Avatar
banjopicker66
I would suggest you confirm that the "firewall" is truly what he needs?
I suspect he more likely needs a core support, also known as a radiator support, as they rust out at the bottom quite easily. They are repopped, by the way.
But a firewall? This doesn't make sense as it sits up high in the front of the cab under the windshield. I n all the trucks I have worked on, even on some of the most rusted out, unfixable and unsalvageable cabs, I have never seen a rusted out firewall. Even if the issue isn't rust, replacing the firewall requires dissecting the welded cab body pieces.
If he truly needs a firewall, he is looking at an incredible amount of work, and would probably do much better, faster and cheaper to obtain an entire replacement cab.
Just my opinion, but I hope this helps.
John - the other John
Old Dec 8, 2014 | 04:26 PM
daveengelson's Avatar
daveengelson
If the area is not too seriously rusted may want to consider patch kit?? Had some rust issues w/ the firewall on the 65; fortunately not serious enough to require cutting and welding patch panels. There were a couple questionable areas so I used a floor pan-trunk repair patch kit; Eastwood, or Por's 15 carry them; basically consist of fiber cloth, epoxy putty, and paints. I then bought the 'firewall pad/cover' which completely cover the entire firewall area. If the firewall has serious cancer, as Banjopicker mentioned, suggest check out the condition of the radiator support.
Posting pic of the 'firewall pad' as an example only:
http://cdnll.dennis-carpenter.com/im...101670-ABS.jpg
Old Dec 8, 2014 | 06:54 PM
ihcc104's Avatar
ihcc104
There is a guy on here who is dismantling a 66 cab and sending out parts.
His name is Eric, resonateur.
Give him a PM and tell him what panel she is looking for...
Hope it helps
Old Dec 8, 2014 | 07:26 PM
66with352's Avatar
66with352
Here is a picture of a rotted firewall. Is this the area or part you are referring too??
Old Dec 8, 2014 | 07:32 PM
banjopicker66
Yep, that's the firewall.
Rusted out, too by the looks of it!
John -
Old Dec 8, 2014 | 08:58 PM
yankbs 66f100's Avatar
yankbs 66f100
they can't get anything past you John. LOL
jwheel1969
Apr 19, 2011 09:55 PM
blackford85
Nov 8, 2006 03:20 PM
steve butera
Paint & Bodywork
Jan 14, 2004 07:08 PM
HardFordCore
Sep 23, 2003 09:31 AM
Russell Leonhardt
Jul 21, 2000 05:58 PM
