Beating a dead head subject.
Old Dec 4, 2014 | 04:52 PM
  #31
BLADE35's Avatar
BLADE35
Cab off not a problem bud
How it's done lol
Old Dec 4, 2014 | 04:54 PM
  #32
BLADE35's Avatar
BLADE35
And no it's not my truck
Just thought I'd give you boys something to laugh about
I know some of you have seen this already
Old Dec 4, 2014 | 05:22 PM
  #33
happscrap's Avatar
happscrap
Lmao... wow!!!!
Old Dec 4, 2014 | 06:19 PM
  #34
Yahiko's Avatar
Yahiko
FTE Remembers
How it's done lol
Hope that is not in California. The Shake and Bake would not go over well.
Well I should call it Shake, flatten and bake. The blocks stacked that high
scare the living you know what out of me.
Makes you think of this
Diaper change?
Sean
Old Dec 4, 2014 | 08:08 PM
  #35
happscrap's Avatar
happscrap
I call stupid....
Old Dec 4, 2014 | 09:30 PM
  #36
Yahiko's Avatar
Yahiko
FTE Remembers
Originally Posted by happscrap
I call stupid....
Someone almost got to call the guy with the scraper and a sponge
to clean that one up.
Sean
Old Dec 4, 2014 | 09:45 PM
  #37
happscrap's Avatar
happscrap
Sean
You ain't kidding.. He was lucky...
Old Dec 4, 2014 | 10:12 PM
  #38
Yahiko's Avatar
Yahiko
FTE Remembers
One reason I will never cross under any load that is up in the air.
If I don't have a need to be under it then I won't be. People I have
worked with in the past don't get it and I explain it and still.
Some day they might get it without "getting IT"
The IT in this case being squished. Never want to have to clean that up
of tell someone that someone is not coming home after work.
Sean
P.S. Testing the RED Fox. What do you think?
Old Dec 4, 2014 | 10:22 PM
  #39
happscrap's Avatar
happscrap
Sean
I hear you about getting under loads. I'm a certified arborist, owner of a large tree service company and we study dynamic and static loads and rigging. I have hanged over 4k from a rope over a homes at least 1000 times. Static loading is safer as dynamic loading adds mass weight to its load. If your playing with weight you better understand the risk and be trained on both sides of the coin. Or you will end up... well with a scraper as you put it! Lol
Ps. I like the red fox..
  #40
dannyboy950's Avatar
dannyboy950
The fox looks good.
Old Dec 5, 2014 | 07:28 AM
  #41
BryanStein's Avatar
BryanStein
Keep in mind the ford manual is based on head bolts and not head studs.
One of the first guys that did suds and heads with the cab on posted that, for the rear studs, you have to insert the studs in the heads, holding them on with rubber bands on the top of the heads, before lowering the heads onto the block. There's not enough room to install the heads after installing the rear studs.
Old Dec 5, 2014 | 07:37 AM
  #42
happscrap's Avatar
happscrap
Great info. I've read that some guys have dented there fire wall a little to get the torque wrench on as the special snap on tool doesn't work on the apr studs.
But your saying you can do the apr studs in cab but when installing the the head place studs in head and rubber band them.so they stay flush with the bottom of the head while placing head in truck??
Old Dec 5, 2014 | 07:44 AM
  #43
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Or hammer a dent into the firewall
Josh
Old Dec 5, 2014 | 08:02 AM
  #44
MisterCMK's Avatar
MisterCMK
Both it them are stupid
Sent from my Telegraph using IB AutoGroup
Old Dec 5, 2014 | 12:30 PM
  #45
Yahiko's Avatar
Yahiko
FTE Remembers
If you read in the 2006 Ford Workshop manual they also say that the back
bolts can't be installed without first putting then into the head before you
lower it into place.
Sean
